Is there a stand alone version that runs off of a usb stick? If not what’s a good capture software that does?
Yes. You can see it at the OBS studio page here:
https://www.videohelp.com/software/Open-Broadcaster-Software
Scroll a bit down the page and you'll see a link to the portable versions:
https://www.videohelp.com/download/OBS-Studio-26.0.2-Full-x64.zip
https://www.videohelp.com/download/OBS-Studio-26.0.2-Full-x86.zip -
thanks, i meant to say portable. Can i run it directly from the folder on the hd and if so how?
How to capture anything with Obs Studio
By Baldrick in forum User guidesReplies: 1Last Post: 8th Sep 2021, 02:10 -
Hauppuage PVR2, OBS Studio, no sound?
By FussyBob in forum Capturing and VCRReplies: 24Last Post: 7th Sep 2020, 13:32 -
Question regarding cropping in OBS studio
By rocknrolla115 in forum ComputerReplies: 0Last Post: 21st Dec 2019, 17:24 -
inconsistant video seeking from OBS studio records
By Golem in forum Newbie / General discussionsReplies: 16Last Post: 10th Apr 2019, 11:33 -
How to record ANYTHING on your screen using the free OBS Studio!
By Baldrick in forum User guidesReplies: 0Last Post: 7th Dec 2017, 05:45
