Hi i try to make some videos where i use my hands.
But my hands close up is really ugly.
Is there a way to make them look less ugle by make them more pale og blur them?
If your hands are mostly at the bottom of the picture, you could re-light the scene and have the bottom of the frame dark.
The green gloves is a clever idea, but you'd end up with a pretty ghostly image, if you replaced the green with something else.
If you have a program which has motion tracking, you could use that, but it would be a lot of work.
Changing the distance between you and the camera, and then using the zoom to re-frame the scene can also work. A camera which is close to you, and uses a wide angle setting will make your hands look much larger. If you move the camera further away, and then zoom in to get the same area in the frame, your hands will look smaller.
You can also experiment with the camera angle. If you move the camera slightly above your eye level, your hands will be further away from the lens and therefore appear smaller. For this trick, you should go back to using a wide angle setting with the camera close. This will make your upper body look larger, and things further away will look smaller by comparison.
Neat video "colorizes" wrong color hands and face
By mammo1789 in forum RestorationReplies: 4Last Post: 25th Aug 2020, 15:21 -
Remove hdr without converting. Just remove hdr from mkv files
By fits79 in forum Video ConversionReplies: 9Last Post: 12th Jun 2020, 12:02 -
Serious flaw that lurked in sudo for 9 years hands over root privileges
By El Heggunte in forum ComputerReplies: 2Last Post: 6th Feb 2020, 07:48 -
What is this, and can I remove it?
By sventamyra in forum RestorationReplies: 20Last Post: 25th Feb 2018, 11:38 -
Need Help Batch Remove Audio,Remove Subtitle,Change Default Audio and Sub
By Inoyama in forum Newbie / General discussionsReplies: 9Last Post: 9th Jan 2018, 15:20
