Hey everyone, appreciate any input.
I just captured this footage from a VHS tape. Lossless NTSC capture to UTVideo. AG1980 > Datavideo TBC6000 > ATI TV Wonder 600.
The interlacing on this footage is a bit messed up. 99% of the time I get normal TFF that I can properly deinterlace. Since this footage was originally PAL HI8 and this tape is maybe a 4th generation, I assume some bad conversion happened along the way.
Seems like a duplicate frame is inserted somewhere in here.
Is there any better program to separate out these fields for inspection? Doing so via VirtualDub is tiring and hard to make sense when you have an issue like this.
End result i'll be processing in AviSynth. Might just drop the dupe frame via the script if I can't figure it out.
Sample: (160mb)
https://nicholasserra-dropbox.s3.amazonaws.com/videohelp-field-order-sample.avi
Thanks!
Results 1 to 1 of 1
FFMPEG to transcode 50i h264, problems with field order
By ffml in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jul 2020, 05:02 -
Interlacing and field order problem
By Boklavdi in forum Video ConversionReplies: 33Last Post: 26th Apr 2020, 13:05 -
AmaRecTV and field order
By Mr Chris in forum Capturing and VCRReplies: 19Last Post: 16th Aug 2019, 14:50 -
How to fix annoying field order problem on DVDR directly recorded from VHS?
By EddyH in forum Newbie / General discussionsReplies: 10Last Post: 5th May 2017, 11:47 -
DGIndex and Field Order Transition
By JapaneseIdolWota in forum Video ConversionReplies: 3Last Post: 18th Oct 2016, 09:16
