Hey, so I stumbled onto something about AVCHD discs today and starting wondering if encoding this way allows for more content without loss of quality vs. a standard Blu-ray Disc burn, and I can’t seem to find any clear answers searching the web. I’m brand new to the concept so I don’t know how any of it really works, but I was intrigued. Could anyone answer this question and break down the basics for me? Thanks!
Results 1 to 11 of 11
The bitrate determines how much you can fit on a disc
filesize = bitrate * running time
BD allows for a higher bitrate, and thus higher potential quality
AVCHD v1 allows for < 24Mb/s bitrate , AVCHD v2 < 28Mb/s , BD <40Mb/s for max rates
The higher the bitrate (if everything else is the same), the higher the quality, the less you can fit on a disc
so if you chose to use a lower bitrate for BD encoding the same as some other AVCHD disc, it would be the same amount you could fit on a disc -
What are you trying to put on the AVCHD?
A rip/download or something from another source like VHS? -
I’m trying to back up my tv show collection, so the sources would be predominantly DVD and Blu-ray rips. It’d be nice to fit more onto each disc if possible, though.
I reckon most will tell you to just back up to a hard disk and avoid re-encoding all together.
Poisondeathray pretty much laid it out.
Shick out the descriptions here and on wikipedia.
I recckon converting DVDs to an AVCHD would mean getting better quality at a smaller file but I doubt it for Blu Ray. -
I think you missed the significance of this:
What that's telling you is this: you can put as much running time as you want on a Blu-ray or AVCHD disc by using lower bitrates. But the lower the bitrate you use the worse the quality. You have to decide for yourself how much quality you are willing to lose. And you have to do that on a case by case basis -- different videos require different bitrates. -
There might be an opportunity to re-encode DVDs with a difference AVCHD compliant codec that might save you some space without quality loss but Blu-Rays will likely lose some. It might not be noticeable though...
save as data ? it doesn't matter which compression you use, most codecs are supported, only no fancy menus, only file structure on screen.
Optimum bitrate for SD content upconverted to Blu-Ray 1080i?
By brassplyer in forum Authoring (Blu-ray)Replies: 5Last Post: 2nd Jan 2017, 11:36 -
How to Ripping Subtitles from Blu-ray / HD-DVD / CBHD Video Content?
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 20th Oct 2016, 08:36 -
How to Rip Closed Caption from Blu-ray / HD-DVD / CBHD Video Content?
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 19th Oct 2016, 13:34 -
AVCHD vs. Blu ray structure, what's the difference?
By jbitakis in forum Authoring (Blu-ray)Replies: 12Last Post: 29th Apr 2016, 07:33 -
1920x1080i 25 Huffyuv avi to a blu-ray compatible standard? AVCHD?
By RossDaBoss in forum Video ConversionReplies: 1Last Post: 18th Dec 2015, 07:56
