Hi! Newbie here. Just registered. I am trying to convert a bunch of old ballet videos (The Nutcracker and various others) to eventually upload to YouTube so that all dancers have access. (Some dancers have never even seen video of themselves! I have videos from 1983 through 1999).
I was able to convert the VHS to DVD, and then I used the VLC program to convert the VOB files to mp4 (for upload to YouTube). The video is fine. The audio is fine in the beginning, but around 20 minutes in, the audio lags. I figured out how to adjust the audio (in VLC) so that it's in sync with the dancing, but the problem is that it adjusts the entire 90 minute file. How can I go about this? I was thinking maybe I could adjust the volume separately, but I'm not even sure where to begin. The entire ballet is split into 4 VOB files after converting from VHS to DVD, and the audio issues seem to only be with the 2nd, 3rd, and 4th files. Please help! I wanted to have this completed as a surprise for all of the dancers since this is Nutcracker "season" and everyone is stuck at home with no live Nutcrackers to go see. Thank you in advance!
If the dvd plays fine, you should rip the entire movie (not the single vob's) to your hard disk and convert the ripped full movie.
You can do this with clever FFmpeg-GUI (for unprotected DVD only). -
If the video is fine (without stuttering), then you could try ripping just the audio from the VHS, as pcm (wav) uncompressed. This takes less system resources than compression. When this audio track is in sync, you can compress it as you wish and mux it to the video.
[Attachment 56180 - Click to enlarge]
Thanks, hech54. I will give the reviews and program a read. Do I need to copy the DVD to my computer or can I just run the DVD files themselves through the FixVTS program directly? I used a Magnavox VHS to DVD converter first, and that's where the DVD came from. It's split into files on the DVD itself. (See attached). -
I say "work with a backup copy" automatically......never mess with the original. As long as there is an original available somewhere else.....go for it
VHS to DVD quality issue
By cinemakyle01 in forum Video ConversionReplies: 96Last Post: 19th Sep 2021, 15:34 -
sync issue
By borofc71 in forum Newbie / General discussionsReplies: 13Last Post: 4th Jun 2018, 05:32 -
Converting VHS to DVD desktop pc
By oduodui in forum Capturing and VCRReplies: 3Last Post: 30th Apr 2017, 07:16 -
I need some help converting my old VHS, VHS-C, and 8mm/Hi8 tapes. Many Q's!
By CZbwoi in forum Capturing and VCRReplies: 80Last Post: 20th Apr 2016, 16:17 -
Converting VHS tapes to Digital - VFR Audio Sync Issues
By Foolio64 in forum Video ConversionReplies: 2Last Post: 9th Jan 2016, 12:59
I read some posts after I posted this morning, and I saw the suggestion of using
