I wonder what's the best quality audio I can get from Youtube? Using such as youtubedl ?
There is a site I like to download (tiffany poon) and I'd like to get the highest possible audio file.
I suppose it depends on what Tiffany uploads to Youtube?
And on how I download? Does youtubedl set for 'best quality' (the default I think?) get wav if it can and that will be in the resulting mp4 I get?
If wav was uploaded could a lossless compression be downloaded 'on the fly' cutting the download time?
What should I do at my end?
What should I advise/ask Tiffany to do at her end?
Results 1 to 13 of 13
Use the -F parameter to have youtube-dl list the available formats, it will also indicate which it considers best. You can then use the -f parameter to choose the audio / video you want.
To get the 160k opus with the 1080p vp9 video you would use -f 251,303Code:> youtube-dl -F https://www.youtube.com/watch?v=SQE823HGcgc [youtube] SQE823HGcgc: Downloading webpage [info] Available formats for SQE823HGcgc: format code extension resolution note 249 webm audio only tiny 63k , opus @ 50k (48000Hz), 6.32MiB 250 webm audio only tiny 81k , opus @ 70k (48000Hz), 8.33MiB 140 m4a audio only tiny 131k , m4a_dash container, mp4a.40.2@128k (44100Hz), 15.08MiB 251 webm audio only tiny 155k , opus @160k (48000Hz), 16.16MiB 160 mp4 256x144 144p 99k , avc1.4d400c, 30fps, video only, 8.30MiB 278 webm 256x144 144p 100k , webm container, vp9, 30fps, video only, 10.74MiB 133 mp4 426x240 240p 147k , avc1.4d4015, 30fps, video only, 12.68MiB 242 webm 426x240 240p 224k , vp9, 30fps, video only, 22.01MiB 134 mp4 640x360 360p 291k , avc1.4d401e, 30fps, video only, 24.25MiB 243 webm 640x360 360p 411k , vp9, 30fps, video only, 41.86MiB 135 mp4 854x480 480p 443k , avc1.4d401f, 30fps, video only, 36.37MiB 244 webm 854x480 480p 745k , vp9, 30fps, video only, 67.91MiB 298 mp4 1280x720 720p60 1014k , avc1.4d4020, 60fps, video only, 68.28MiB 247 webm 1280x720 720p 1515k , vp9, 30fps, video only, 165.60MiB 136 mp4 1280x720 720p 1831k , avc1.4d401f, 30fps, video only, 153.21MiB 302 webm 1280x720 720p60 2653k , vp9, 60fps, video only, 197.66MiB 299 mp4 1920x1080 1080p60 3482k , avc1.64002a, 60fps, video only, 297.38MiB 303 webm 1920x1080 1080p60 4464k , vp9, 60fps, video only, 497.38MiB 18 mp4 640x360 360p 706k , avc1.42001E, 30fps, mp4a.40.2@ 96k (44100Hz), 82.27MiB (best)
If you just want the audio you leave out the video format id.Code:> youtube-dl -f 251,303 https://www.youtube.com/watch?v=SQE823HGcgc
Very excellent. Thank you.
So we cannot get uncompressed audio download from Youtube? Even if they uploaded wav we can't bring it down?
And what is the audio in what youtube-dl has listed as 'best' there?
And did you pick the 160k opus with 1080 vp9 simply as an example for me or would you consider it better than youtube-dl's pick? -
That's right, you can't.
zing269 already told you. Number 251, the 4th one down.And what is the audio in what youtube-dl has listed as 'best' there?
What? Start making sense. The 160k Opus is the best available in that video.And did you pick the 160k opus with 1080 vp9 simply as an example for me or would you consider it better than youtube-dl's pick? -
No. Maybe the uploader can, but even that is not guaranteed, and complicated, and if it's possible today it could be removed tomorrow because the powers-that-be decided so.So we cannot get uncompressed audio download from Youtube? Even if they uploaded wav we can't bring it down?
It reads : mp4a 96k, i.e. AAC audio at 96kbps (that's the bitrate in kilobits per seconds in case you don't know — after all it's the newbie section). So it's lower quality than the m4a audio obtained with code “140”, at 128kbps.And what is the audio in what youtube-dl has listed as 'best' there?
It's called “best” because it's the best format that is available as already merged video + audio streams in a single file, so if you type “-f best” that's what you get (although it's far from the best possible quality in this case since the video is only 640x360 at 706kbps) ; all other formats are either video only or audio only, and they have to be merged accordingly. It's a bit confusing admittedly.
You asked for the best possible audio, in this case it seems to be the OPUS 160kbps, so that seems like the best option indeed (and in this case, the “303” WEBM/VP9 video stream also seems to have the highest bitrate, 4464kbps, compared with the best available MP4/H.264 stream, 3482kbps, which is not always the case — it should be noted that those bitrates reported by youtube-dl aren't always accurate). I've read conflicting statements regarding the compared quality of AAC and OPUS compression, but at 160kbps vs. 128kbps the former is definitely better.And did you pick the 160k opus with 1080 vp9 simply as an example for me or would you consider it better than youtube-dl's pick?
@manono
No, the O.P. wrote and meant : the one listed by youtube-dl as “(best)”. See above.zing269 already told you. Number 251, the 4th one down.
Relax, it's the newbie section! Whatever happened to “there are no dumb questions” ?What? Start making sense.Last edited by abolibibelot; 10th Dec 2020 at 15:49.
Obviously "mp4 640x360 360p 706k , avc1.42001E, 30fps, mp4a.40.2@ 96k (44100Hz), 82.27MiB (best)" isn't the best. As near as I can tell, it's the only one that includes both video and audio. It's both the best and the worst. It's the only. The best is what zing269 provided.
So, you leave your brain in a box when proclaiming yourself a newbie? I've never used YTDownload in my life but can understand what was written in that list. A little common sense can work wonders. You used a whole lot of words to repeat what I said earlier, and mine is much more easily understood. Until you began your gratuitous attacks.Relax, it's the newbie section! Whatever happened to “there are no dumb questions” ?Last edited by manono; 10th Dec 2020 at 20:01.
I'd like to thank you for your post. Very informative. Very pleasant. Heartening. I learned from it.
And I would like to apologise for being the cause of exposing you to fairly disgraceful ad hominem attack. I suppose you already know it but if you don't then know that we just have to ignore them, there's literally no sensible communicating with them.
More power to your elbow. Thanks again.
[manono]
No it's not the worst, it goes down to 256x144. If you wanna stay grumpy, at least try to be accurate.Obviously "mp4 640x360 360p 706k , avc1.42001E, 30fps, mp4a.40.2@ 96k (44100Hz), 82.27MiB (best)" isn't the best. As near as I can tell, it's the only one that includes both video and audio. It's both the best and the worst. It's the only. The best is what zing269 provided.
1) Wow... where did I “attack” you ? What word are you gonna employ if you get raped by some crack addicted, AIDS infected pitbul on your way home tomorrow night ?So, you leave your brain in a box when proclaiming yourself a newbie? I've never used YTDownload in my life but can understand what was written in that list. A little common sense can work wonders. You used a whole lot of words to repeat what I said earlier, and mine is much more easily understood. Until you began your gratuitous attacks.
2) Please consider that not everyone is as enlightened as you are... you've been a member here since 2003, while “abrogard” has only been a member since... wait... 2002 ? O_o Hem, scratch that !
3) Your post hadn't yet appeared when I posted mine (it happens). Sorry to have foolishly diluted its laconic magnificence with my therefore redundant reply, which, I apologize, used more words, of which I should know that resources are scarce on this planet.
4) You, sir, seem to have serious anger management issues. Perhaps try meditation. Or shooting at stuff bare chested with an AK47. (Accept no substitute.) If all else fails, try this.
[abrogard]
Is that a common saying in Australia ? My elbow's kinda dirty after almost a year of coughing and sneezing at it... é_è (*joking*)More power to your elbow.
In all fairness, it's a bit puzzling in retrospect that you asked such basic questions as an 18 years member on this forum. But who knows, perhaps you're a clever kangaroo ! (In the marvelous movie Arrival by Denis Villeneuve, the main protagonist, a high level linguist, tells a military officer a story about how european explorers who “discovered” Australia tried to communicate with the natives, asking them how they called those weird animals, and the reply was “kangaroo”, but later it was found out that it in fact meant “I don't understand” — then she tells her physicist partner in attempting to communicate with “heptapod” aliens that it was all b.s. to get her point across that extra time was required to build the foundations of a sensible communication between vastly different intelligences.)Last edited by abolibibelot; 10th Dec 2020 at 22:44.
"Programmers are human-shaped machines that transform alcohol into bugs."
FLAC would be the next option.
How to download YouTube videos with no quality loss?
By Master Tape in forum Video ConversionReplies: 55Last Post: 29th Jun 2021, 14:29 -
Question how to bulk download just audio from youtube playlist
By jimdagys in forum Video Streaming DownloadingReplies: 0Last Post: 18th Apr 2020, 21:18 -
Youtube-dl How to download this video in this quality from Iplayer ?
By Fredmason in forum Video Streaming DownloadingReplies: 2Last Post: 20th May 2019, 08:10 -
Downloading best quality audio from youtube, and in general
By getwellsam in forum AudioReplies: 7Last Post: 5th Jun 2018, 17:37 -
How well does Youtube preserve video/audio quality over the years?
By bitrape in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2016, 14:17
