I extracted dvd subtitles in .srt format with dvdfab and muxed them on mkvtool. During muxing I get this warning (Attention to line 3701: the initial timestamp is smaller than the previous element. All the elements of this file will be sorted according to the initial time)
when I open the movie the subtitles come out overlapping and in a messy way. Does anyone know how I can fix it? How can I extract subtitles from a DVD correctly? thanks I await your news
Load the srt and the video in subtitleedit and correct the sub timings. Then remux with mkvtoolnix.
It depends on how bad the timings are screwed up. With Subtitle Edit you can correct a constant offset, change framerate, visually sync, etc.
And of course there is manually editing the timings, which is quite a task...
Maybe you want to try both extracting & OCR-ing the subtitles with Subtitle Edit and go from there.
How to name subtitles in mkv files?
By Bassquake in forum SubtitleReplies: 2Last Post: 17th Apr 2020, 14:11 -
Reasonably automated method for converting DVD subtitles for MKV?
By Asterra in forum Video ConversionReplies: 7Last Post: 29th Dec 2019, 03:31 -
Subtitles for 4K Uktra HD MKV
By Reddwarf4ever in forum SubtitleReplies: 13Last Post: 16th Nov 2019, 05:54 -
Remove Subtitles From MKV - How?
By Evokazz in forum Video ConversionReplies: 11Last Post: 28th Aug 2016, 19:43 -
extract all subtitles from a mkv
By Valit in forum SubtitleReplies: 4Last Post: 10th Jan 2016, 18:10
