Capturing old VHS video virtual dub and as I watch it play on the window in Vdub everything looks normal. The output avi file however is out of sync. Any one know why? The settings im using are the lagararithc lossless codec for compression, 29.97 frame rate color space UYVU outpize size 720x480. Not sure if its a Vdub setting or playback issuse with the vcr or capture card
Update - When using the Hauppage capture software the output file is in sync. it comes out as a .ts file. (im using the hauppage capture card)
my understand though is that capturing it direct to .ts like this results in quality loss vs doing it to the avi file that vdub produces and then encoding it after.
DV File Audio Video Sync Issues - Audio Drift
By Christina in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 2nd Mar 2020, 06:58 -
Easycap DC60 VHS video/audio out of sync
By boriswinner in forum Capturing and VCRReplies: 4Last Post: 18th Nov 2018, 07:21 -
Source video file ok but when burned to dvd, audio is out of sync
By johnnyh55 in forum Authoring (DVD)Replies: 40Last Post: 18th Dec 2017, 13:21 -
Capturing VHS to digital file format in 2016
By Cygnus111 in forum Capturing and VCRReplies: 13Last Post: 2nd Apr 2017, 06:17 -
Converting VHS tapes to Digital - VFR Audio Sync Issues
By Foolio64 in forum Video ConversionReplies: 2Last Post: 9th Jan 2016, 12:59
