i followed the guide on this site to the letter, only i burn the vcd bin with nero not inside vcd easy itself.... but all the vcds i make (tried 2 now) do not play any video in my vcd player. The audio comes out fine. i'm setting it for ntsc and vcd 2.0 which should work fine in this player. Any ideas? i get no error messages at all during any of the converting.
this is my log from vcdeasy
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\temp\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `vcdfirst'
changed publisher id to `VCDEASY_V109'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, E:\movies\vcd1.mpeg
strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
pts start offset 0.340078 (max pts = 3834.122933)
playing time 3833.782856
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 32 (extended psd 56)
iso9660: highest alloced sector is 257 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 240030 video, 47104 audio, 0 zero, 0 ogt, 417 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 288226 sectors [64:03.01]
[CDRDAO Disk Info]
Cdrdao version 1.1.5
2,0,0: TDK CDRW241040X Rev: 6v36
ERROR: No driver found for 'TDK CDRW241040X' (Try to use "Force Driver" in the "CDRDAO settings" page, with 'generic-mmc' for example)
ERROR: Cannot setup device 2,0,0. -
nevermind, i beleive i found the solution on another thready with changing the enviornmental settings in tmpgenc.
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 11:21 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
mkv to divx, picture transition not smooth
By chosen1 in forum Video ConversionReplies: 4Last Post: 28th Jan 2010, 07:02 -
Black and white picture on a Panasonic S53 dvd player with Divx video
By gyzer in forum Newbie / General discussionsReplies: 10Last Post: 2nd Apr 2008, 01:10 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41
