Today, my company asked me to setup a DVR card. It's divided into two parts. First, I've to find a driver for the device, so that the OS may communicate and work with the device. Second, there should be an API (for C/C++) to communicate programmatically with the driver and use its capabilities and functionalities.
I attach pictures of the card.
AOP-4216 and AX8612-AV16N are my only clues, but I couldn't find any driver or SDK in the net. The seller didn't provide any driver. Only a CD is in the box along with the card. There's also no clue on the box. I need the driver and SDK for both Ubuntu 12.04 and Ubuntu 20.04.
After installing the board on my system, lspci gives the following info about it:
BYO, what should be the next step?08:01.0 Multimedia controller: Xilinx Corporation Spartan 3 Designs (Xilinx IP)
Results 1 to 11 of 11
The CD is unreadable. I contacted the agent who bought the hardware and he said he would follow to receive a correct CD, but I think the CD will have nothing to do with Linux, as on the box, the only OS mentioned was Windows XP! There should be an online source. It should have a manufacturer anyway and some company should be responsible for it.
can you run the DVR card under WINE ?? - https://www.pcworld.com/article/2900497/how-to-run-windows-software-in-linux-everythin...%20and%20games.
The first step for running the DVR card under WINE is to run it under Windows. Even Windows can't find a proper driver for it. I examined Windows 7 and searched for the driver in Windows Update (online drivers from Microsoft itself).
did you try the windows 7 compatibility mode ?? - https://www.howtogeek.com/howto/10436/using-program-compatibility-mode-in-windows-7/#:...you%20selected.
I found webpages featuring an AOP-4216 DVR card resembling your card and a page with a software CD for Windows 2000/XP/Vista. One page noted a brand, Anpuwei.
https://www.globalsources.com/si/AS/Yiwu-Kexuan/6008831284842/pdtl/Aop-4216-H-264-16ch...1059005519.htm
https://www.aliexpress.com/i/827109198.html
https://www.newbecca.com/product/523382524563
https://www.newbecca.com/product/528367959194
The card seems to be rather old and is probably out of production. Why do you believe Linux drivers and an SDK exist for this card?Last edited by usually_quiet; 9th Dec 2020 at 23:39. Reason: clarity
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
@october262: There's no software to be run man! At the first step, we need a driver which we don't have. I'm looking for it and come here to discuss about it.
@usually_quiet: Thanks. I'll investigate in them. -
@usually_quiet: They're just sellers of the product. They can't technically support what I need, a driver and an SDK for Linux.
Pioneer DVR-520 and DVR-560 functionality discussion
By jcool in forum DVD & Blu-ray RecordersReplies: 142Last Post: 17th Aug 2021, 20:45 -
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum Capturing and VCRReplies: 30Last Post: 21st Feb 2019, 15:40 -
(avermedia card) Green and Pink screen after DVR software update
By Bruces in forum Capturing and VCRReplies: 6Last Post: 4th Jun 2017, 01:55 -
unable to identify driver for capture card
By codemaster in forum ComputerReplies: 2Last Post: 14th Mar 2017, 11:34 -
record quality drop after digitizing with Video DVR and honestech HD DVR
By andrei186 in forum Capturing and VCRReplies: 1Last Post: 30th Apr 2016, 21:25
