    Dec 2020
    colombia
    Software to zoom every 10 seconds to a video
    Hello I need a software to zoom a video every minute to a 20 minute video,
    I am trying with filmora but I have to do it manually every minute and what I want is to do it only once and for the same software to zoom every minute
  2. Member Cornucopia's Avatar
    "Zoom" how? In what manner? Most people who use the term zoom refer to either optical (via the lens) enlargement or digital enlargement. And when they do it digitally, there is a certain amount of quality loss dependent upon the ratio of enlargement. What's your ratio? What's your center point? What's the speed of the zoom? What are the in & out points of the clip? Will you be incorporating ease-in & ease-out? If so, at what rate?
    These are all questions that will need to be answered to get you closer to what you (think you) want.
    It should be doable with AVISynth scripting, with certain constraints (similar source fileformat, long enough clips, etc).
  3. Zoom ?
    Maybe it's an English translation issue ? Did you mean "trim" or "edit" or cut down to 10 second segments, starting from every minute ?
  4. Vegas Pro contains a scripting language that lets you completely automate repetitive edits. I have written several hundred such scripts, and you can zoom, trim, cut, rotate, and do all sorts of other things, all at a push of a button, and all of them can be automatically repeated on every single clip on your timeline.
