Gday,
I've been at this for "eons" but have had no luck, so I thought I'd tap the experts. I'm a keen user of Picasa. About its only failing is that it will not display some MOV files.
I have the HAALI splitter installed so it will display MP4s, and I have QTLite installed as well.
I have resorted to converting my MOVs to MKVs with MKVToolnix so they display but I would like to have them displayed with no need to convert.
As I intimated in the title, the MOVs that are blank in Picasa also do not display a thumbnail in Windows Explorer.
I would be grateful if someone could provide some guidance (eg codecs to install) to enable MOVs to be visible in Picasa.
Mediainfo for MOV that does show in Picasa and Windows Explorer:
General
Complete name : D:\Alwyn\Alwyn Graphics\Digital Pictures MOV Picasa Test\20201012_074213.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 24.7 MiB
Duration : 12 s 907 ms
Overall bit rate : 16.0 Mb/s
Encoded date : UTC 2020-10-11 23:42:13
Tagged date : UTC 2020-10-11 23:42:27
Writing library : Apple QuickTime
com.apple.quicktime.make : Apple
com.apple.quicktime.model : iPad (5th generation)
com.apple.quicktime.software : 14.0.1
com.apple.quicktime.creationdate : 2020-10-12T07:42:13+0800
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Bit rate : 15.9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 (29970/1000) FPS
Minimum frame rate : 28.571 FPS
Maximum frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.255
Stream size : 24.4 MiB (99%)
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 12 s 905 ms
Source duration : 12 s 957 ms
Bit rate mode : Variable
Bit rate : 92.5 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 146 KiB (1%)
Source stream size : 146 KiB (1%)
Title : Core Media Audio
Other #1
Type : meta
Bit rate mode : Constant
Other #2
Type : meta
Other #3
Type : meta
MOVs that don't show in Picasa
General
Complete name : D:\Alwyn\Alwyn Graphics\Digital Pictures MOV Picasa Test\20200828_151827.MOV
Format : MPEG-4
File size : 5.34 MiB
Duration : 2 s 173 ms
Overall bit rate : 20.6 Mb/s
Encoded date : UTC 2020-08-28 07:19:33
Tagged date : UTC 2020-08-28 07:19:34
com.apple.quicktime.live-photo.vitality- : 1
com.apple.quicktime.location.ISO6709 : -23.1735+117.7477+424.252/
com.apple.quicktime.model : iPhone 11
com.apple.quicktime.software : 13.6.1
com.apple.quicktime.creationdate : 2020-08-28T15:18:27+0800
com.apple.quicktime.content.identifier : A4F2E373-1236-4857-ADB1-6A2AAD66BC5C
Video
Format : AVC
Format profile : High@L5
Codec ID : avc1
Bit rate : 19.8 Mb/s
Width : 1 440 pixels
Clean aperture width : 1 308 pixels
Height : 1 920 pixels
Clean aperture height : 1 744 pixels
Display aspect ratio : 0.750
Frame rate : 29.448 FPS
Minimum frame rate : 13.636 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.243
Stream size : 5.14 MiB (96%)
Color primaries : Display P3
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : lpcm
Duration : 2 s 172 ms
Bit rate : 705.6 kb/s
Bit depth : 16 bits
Stream size : 187 KiB (3%)
Other #1
Type : meta
Other #2
Type : meta
Other #3
Type : meta
Duration : 1 s 402 ms
Source duration : 2 ms
Stream size : 7.39 KiB
Source stream size : 9.00 Bytes
Thanks, Al
Results 1 to 1 of 1
Mercalli Making Blank Files
By blewyn in forum RestorationReplies: 4Last Post: 7th Dec 2020, 08:33 -
Playback is blank on VSDC
By tyaklin in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2019, 17:01 -
Explorer hangs in Win 10 trying to show thumb previews for mkv videos
By sohaibrazzaq in forum ComputerReplies: 1Last Post: 21st Jul 2017, 11:20 -
BD-R blank media questions
By tpapictures in forum MediaReplies: 6Last Post: 7th Jun 2017, 04:23 -
Automactily remove blank scenes
By fang16 in forum EditingReplies: 5Last Post: 19th Sep 2016, 16:29
