Well, I've seen similar posts, but non of them have been able to help me.
I have the webrips of the Skywalker Saga in 4k, and as you may know all of them are in HDR hevc h.265 10 bit format. Unfortunately I don't have an HDR monitor to see them in that format, so you know how they look.
Is there a way to convert them to another format like mp4 or mov WITHOUT loosing quality? Is there any way to convert them to an SDR format (eliminate HDR) without making them look discolored?
I've tried to use handbrake, but it just compressed the mkv I was trying to convert from 20gb to 3gb, didn't really helped.
I'm planning on using them for editing in a software that obviously has problems with these kind of formats and doesn't accept mkv (premiere).
Closed Thread
this probably collides with one of the forum rules:
so I'll not suggest anything specific and try to give general answers.Do NOT talk about warez releases
Like filenames Movie.2012.DVDSCR.X264.AAC.P2P.mkv. Please don't download warez movie/tv releases.
Not unless you use lossless compression which would cause an explosion in the file size.Is there a way to convert them to another format like mp4 or mov WITHOUT loosing quality
There are multiple ToneMapping filters for Avisynth/Vapoursynth/FFMpeg which allow HDR to SDR conversion. 'Under saturation' only happens if you simply drop the HDR information.Is there any way to convert them to an SDR format (eliminate HDR) without making them look discolored?
Afaik. Handbrake offers no support for encoding to HDR or converting HDR to SDR.I've tried to use handbrake, but it just compressed the mkv I was trying to convert from 20gb to 3gb, didn't really helped.
https://www.avsforum.com/threads/guide-easily-encode-your-hdr-uhd-bd-freeware.3008882/ uses StaxRip, but there are tons of other tools which do have HDR2SDR conversion options.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Converting UHD HDR to SDR?
By tommy2010 in forum Blu-ray RippingReplies: 9Last Post: 19th Mar 2021, 04:12 -
Problems converting 4K HEVC HDR-10bit videos to 4K SDR H.264
By Emy78 in forum Video ConversionReplies: 8Last Post: 26th Nov 2020, 23:18 -
Remove hdr without converting. Just remove hdr from mkv files
By fits79 in forum Video ConversionReplies: 9Last Post: 12th Jun 2020, 13:02 -
CONVERT 4K HDR (.mkv) TO 4K SDR (.mp4) - Who helps me?
By Alberto78 in forum Video ConversionReplies: 6Last Post: 7th Mar 2020, 08:38 -
HDR to SDR Avisynth+
By tommy2010 in forum Video ConversionReplies: 2Last Post: 7th Jan 2018, 17:51
