Using nvidia shadowplay to record my system sounds and my microphone audio on two separate audio tracks. When opening the mp4 in potplayer I can only choose one of the two tracks to play with the video. How do I make it so I can have both playing at the same time????
I don't know of ANY (simultaneous) multitrack players, only multitrack editors. (Note: tracks != channels)
Mix down to a single track if you want them to play simultaneously.
Multiple tracks in end-use clips are usually meant for different languages, or karaoke alternates, etc. where you pick the one appropriate one for your circumstance.
Scott -
The feature is likely only available in ffmpeg-based players such as mpv: https://forum.videohelp.com/newreply.php?do=newreply&p=2602922
One use case for mixing mutiple audios is when viewing multiple videos sources on screen (also possible with ffmpeg/mpv). -
In which case, it would likely be called an editor/compositor, no?
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 07:43 -
How to play a VCD with dual language tracks?
By guy24s in forum Authoring (VCD/SVCD)Replies: 7Last Post: 1st Sep 2017, 04:49 -
2 Subtitle Tracks Play on Top of Each Other IDX/SUB
By Bondiablo in forum SubtitleReplies: 8Last Post: 12th Aug 2017, 16:03 -
Sony DV Audio Tracks
By techtron79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 4th Feb 2017, 07:40 -
Time Setting on Dual Boot PC
By bevills1 in forum ComputerReplies: 2Last Post: 30th Jul 2016, 09:33
