I have read a number of topics related to ffmpeg and no such file or directory and still cannot figure out why this is happening
I am trying to extract individual frames from an MKV using the following command C:\Users\me\Desktop\Original\ffmpeg -i video.mkv video%04d.png -hide_banner
If I use C:\Users\me\Desktop\Original\ffmpeg, ffmpeg fires up within cmd prompt
If I use C:\Users\me\Desktop\Original\video.mkv; the mkv will player in media player
However when I try to get ffmpeg to start splitting the mkv, I get file not recognised
I have the 64bit version of ffmpeg installed, I have added ffmpeg to environmental variable path and used ffmpeg -codecs in cmd but still the same issue
I've also used italics around the file name to no avail
I have no idea why/where I am going wrong. It used to work on my last pc without fault which was much more dated
Any solutions much appreciated
Brad
open an command window (cmd)
Enter g.e. ffmpeg -ss 01:44 -i "D:\videos\yourvideo.mkv" -t 00:04 "D:\Images\yourvideo_%03d.png"
This extracts all images of the video from 01:44 for a duration of 4 seconds as png files.
(D:\videos is the path to your video file, D:\Images is the path to the generated images; this path must exist. Adapt both paths to your situation).
ffmpeg -ss 00:00:09 -i "inputvideo" -vframes 1 output.jpg
This will extract 1 frame from inputvideo at 9 seconds.Last edited by ProWo; 5th Dec 2020 at 06:50.
Specify the full path to the input file. If there are spaces anywhere in the path use quotes around the path.
Code:C:\Users\me\Desktop\Original\ffmpeg -i "c:\full path\to\video.mkv" video%04d.png -hide_banner
ffmpeg log file
By lomero in forum Video ConversionReplies: 4Last Post: 3rd May 2020, 02:41 -
Create batch file for ffmpeg to increment the file output
By Bassquake in forum Video ConversionReplies: 2Last Post: 25th Nov 2019, 05:03 -
How to set ffmpeg File Path on Batch File
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2019, 05:55 -
Must files be in same directory as FFmpeg to convert them?
By Spica66 in forum Video ConversionReplies: 1Last Post: 29th Mar 2018, 09:55 -
Ffmpeg ,,, file key!!!!
By supersport in forum Video Streaming DownloadingReplies: 0Last Post: 30th Aug 2016, 08:21
