Hi,
I tried to do frameserving using Windows XP, Virtualdub and Tmpgenc (2.53), I get an error message about a missing file (MSVCR??.dll).
Does anyone frameserve under XP, and using what tools?
Truman,
Thanks, It solved my problem.
What about CCE, is it only version 2.50 that can frameserve?
You can frameserve with VirtualDub to CCE SP 2.25 and 2.50 directly. If you want to frameserve to CCE SP 2.56 or newer, you have to convert the *.vdr with VFAPIconv 1.04b. Then load the *vdr_vfapi.avi into cce.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
Reversing PAL speedup and frameserving
By Ennio in forum Video ConversionReplies: 23Last Post: 28th Jan 2010, 15:28 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
