Hello all!
Some years ago I started to convert some old vhs tapes and it worked quite well by using the following components/sw:
- EasyCAP USB2.0 Grabber (STK1160 Grabber) via component video
- USB-AVCPT Driver (I don't know, where I had this driver from unfortunately)
- utvideo 19.1.0 codecs
- VirtualDub 1.10.4
Now, I wanted to continue using the same hard/software. Everything was still installed on the same computer but I can not get it to work anymore. It only outputs black and white video. Unfortunately, I do not know a lot about video or color formats, so if there is some info that I forgot to mention, please bear with me, tell me and I will look it up!
I already tried to update some software. I tried the current version of VirtualDub 2 and utvideo v22.
I would really appreciate some hints to some things I could try! Thank you in advance already
Greetings from Germany,
Thomas
Okay, nevermind. After fiddeling with this for almost 3 hours, I found out what the issue was some minutes after desperately posting here.
Had to go to capture filter and set to PAL_B apparently. Now it works like a charm!
Cannot see picture using VirtualDub and EasyCap
By Christop in forum Capturing and VCRReplies: 14Last Post: 31st Jul 2020, 11:34 -
EasyCap strange issue while recording VHS
By jackichan2004 in forum Capturing and VCRReplies: 11Last Post: 13th May 2020, 14:33 -
(EasyCAP DC60) Audio plays before the video, using VirtualDub
By p0zopa in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2018, 11:40 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 20:05 -
EasyCap shows up as OEM Device in VirtualDub - No video signal! How to fix?
By elgy in forum Newbie / General discussionsReplies: 1Last Post: 24th Mar 2017, 10:36
