hey guys ,you know i have a lot problem using burning softwares such as
fireburn ,nero etc. to burn a vcd so i just have a small question to ask.
I haved turned my media into a mpeg then i turned it into 2 files using vcd easy : a cue file and a bin file.My burner doesn t work with nero,fire burn,vcdeasy but i have a burning software thats named hotburn.Thats what i use to burn cds to cds and my mp3s.So if i drag and drop the bin.file and the cue.file in to the data cd box and write it in a cd will it work
in my dvd player as a vcd? Or can i just copy the mpeg into my cd and it ll
work in my dvd player?please help me.if you don t know nothing about it
please give me another way to burn a vcd.Thank you
Is this the latest version of Nero? and have you tried Easy CD creator?
Tony
p.s. Easy Creator sucks but it will burn VCD's -
look for an option to burn image, then load up the .cue file. this is the file that tells the authoring program how to burn the image(the .bin file)
it should work with no problem. the other option is to download daemon tools, mount the image as a virtual CD, and do a direct disc copy with your burning software. -
i downloaded the daemon tools but when i go to
virtual cd\dvd-rom then device 0:F then mount image then
i selected the image file(bin file),then nothing comes.
I don t mean to bother you guys but can you help me in details please.
My father is killing me to make a damn vcd so can you guys help me out.
Thanks -
a proggie called fireburner is really good a burning bin/cue files, goto www.fireburner.com and download the trial version
you can PM me and i'll give you the reg info to get full version -
once you've done this, your image is mounted as a virtual CD rom on your computer...if you go under my computer, you'll see an extra CD drive. what you do then is do a direct CD copy with that virtual drive as your source, and everything should work perfectlyOriginally Posted by akuma
Idiot's Guide to Encoding
By sharpfocus in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2011, 20:59 -
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
Idiot proof way... Blu Ray to WTV
By Chakotay2 in forum Video ConversionReplies: 1Last Post: 27th Sep 2010, 07:17 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 17:12 -
Nero help for newbie IDIOT
By bbassboat in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2008, 18:32
