Hello. This may be a super simple problem for the smart folks here. In which case I'll be out of your hair in no time. I didn't know what question to ask you actually.
I've always been able to record video on my Canon PowerShot A1100 IS and then transfer it to my computer (Asus Vivobook, win 10, 64 bit) and do what I want with it, include upload it to Bitchute. (I just plug the SD card directly into my laptop.) I couldn't edit it in Avidemux (just cropping it which is all I know how to do) either. I tried this and that, but I'm clueless about video, so I didn't go crazy. I just changed the output. The only thing Avidemux would do is 'dummy', but I have zero idea what that means and it doesn't register on my computer. It shows as mkv. The file says AVI. That setting in Avidemux doesn't work. I reformatted the SD card. No luck. I asked a guy at The Source here in Toronto what it might be and he said that if I can playback the video on my camera, there should be no problem. I can. I can play it back on my laptop. I just can't edit it or upload it. Should I try a new SD card? Another other suggestions? Thanks in advance.
* About 32 trillion $ sit, untaxed, in offshore tax havens, while 'leaders' whine that they can't afford social spending!! *
try reading the AviDemux tutorial - https://www.avidemux.org/admWiki/doku.php?id=build:doctop
can you try connecting your camera to your computer via USB cable and transferring the video that way ??Last edited by october262; 1st Dec 2020 at 19:45.
I didn't need the tutorial before. I don't use Avidemux differently now and I don't use it for anything other than clipping videos (lenthwise). I wouldn't know how to do more. And I wouldn't understand the jargon in the manual. Read my post.
Processing video
By carlmart in forum Video ConversionReplies: 8Last Post: 17th Apr 2019, 11:52 -
FFMpeg cutting without re-encoding // AviDemux keep aspect-ratio info
By vpvaxn in forum EditingReplies: 6Last Post: 15th Apr 2017, 21:53 -
Need help with batch processing Avidemux for OS X
By SetoTitan in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2017, 15:24 -
Tsmuxer Batch Processing
By ron spencer in forum Video ConversionReplies: 2Last Post: 20th Apr 2016, 18:01 -
ffmpeg post processing,...
By Selur in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2016, 09:49
