Hi. I am not a professional video editor. I used ffmpeg with x265 to convert my videos a lot. By using it, I was using crf setting to reduce file size. But there is no option like this in hevc_nvenc. What can I use to encode my videos similar to crf? Thanks.
Unless of course you want to spend the money on Main Concept, who have managed to combine CRF with NVENC:
https://www.mainconcept.com/fileadmin/user_upload/datasheets/HEVC_SDK_DATASHEET.pdf
https://www.mainconcept.com/hybridgpu.html
For those of you that may have trouble understanding the above, Main Concept added CRF to their software encoder a while ago, and then they used NVENC's ability to use external rate control mechanisms to create a hybrid GPU powered encoder that uses CRF.
It's not cheap, but it does exist.
For the record, Intel's QSV also has the ability to use external bit rate control mechanisms, so there's nothing stopping someone from creating a hybrid QSV encoder with CRF.Last edited by sophisticles; 3rd Dec 2020 at 12:05.
CRF values?
By Chauceratemyhamster in forum Video ConversionReplies: 18Last Post: 28th Mar 2021, 22:06 -
CRF Values
By Anakin in forum Video ConversionReplies: 11Last Post: 7th Sep 2020, 19:12 -
FFMPEG - hevc_nvenc & h264_nvenc lossless presets not truly lossless?
By AnomalyDetected in forum Video ConversionReplies: 5Last Post: 27th Oct 2019, 03:24 -
ffmpeg h.265 -crf problems :(
By niftybunny in forum Video ConversionReplies: 7Last Post: 10th Mar 2016, 02:11 -
DVDFab 9 CRF, Handbrake/Vidcoder x264 CRF
By hogger129 in forum Video ConversionReplies: 10Last Post: 30th Dec 2015, 11:51
