Hi to all, i was wondering if there was anyone who would like to help me out, i would like to know the easiest & quickestn way to DVD rip! any software etc that i need, very very inexperienced at doing this so all help would be appreciated
thanks for your time with this
Pearly
Hi pearly
I have used DVD2SVCD for a while now and have found that the results exceeded my expectations. After the initial setup (9 pages of easy instructions) I was off and running. You can find this at
www.doom9.org
The instructions are there. You will also need TMPGenc. you can find this on this website
Regards
Hypnotic_Moose
The easiest Way With Fantastic quality results for me is the combination of two Peogrammes.The first is the Dvd-x and the second is the Tmpeng encoder.Inside the Dvd-x it has instruction how to do that.Both Programs you can Download it from www.cdrsoft.cc Believe me I'm very happy to use these software and its very easy.
The simply is the best for me.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Ripping Saw 6 (Saw VI) dvd, HELP!!!
By diluvian8 in forum DVD RippingReplies: 5Last Post: 27th Jan 2010, 23:45 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
Ripping DVD'S
By bamf321123 in forum DVD RippingReplies: 3Last Post: 23rd Jun 2007, 05:57 -
Ripping DVD'S
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 05:14
