Hi.
Is there any EASY program that can convert really quick as possible(I don't care about the final size of the video file).
And i want this program support even the latest video files(At picture and sound).
I want all video files(Mostly mkv) to convert it as it is the picture and all dts sound to ac3 or trueac3.
I already know the
01. Clawn bd
02. PopCorn MKV AudioConverter
03. Avidemux
04. UsEac3to
And all of these need too many parameters e.t.c.
And i need a really easy to use program cause it isn't for me but for one friend and doesn't know very well pc e.t.c.
Results 1 to 12 of 12
There is an online converter on media.io, its easy to use too. I can't say how the quality will turn out, as i never converted mkv to ac3 myself. But it doesn't hurt to try it out.
Here is the link: https://www.media.io/convert/mkv-to-ac3.html -
To use this program full i must buy it.
Don't you have a free?Last edited by fits79; 30th Nov 2020 at 09:39.
How odd, i was able to use it for freely but it probably has an upload limit or is restricted in formats. I'm really sorry for the inconvinience, i sadly don't know any other programm you already listed in your first comment
I suggest myffmeg. It isn’t free but you can try before you buy, it’s not expensive and frequently updated. In your case you can queue one video file, set the parameters you want like change audio from DTS to AC-3 (or enhanced AC-3), remove subtitle tracks if required, then add additional files and they will automatically be set to the parameters of the first file.
I have already try that.
I must first convert mkv to ac3 and then re-add that ac3 to mkv file so is 2 steps that i must do it manually to every movie file.
I want one simple and as automatic is done program that i can add more than 1 video file and convert them all to same file name but ac3 sound.Last edited by fits79; 13th Dec 2020 at 16:41.
This is a free program and it does it in one go Popcorn Audio Converter https://www.videohelp.com/software/PopCorn-MKV-AudioConverter It requires a number of helper apps but directs you to get them.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
batch convert DTS to Ac3 using ffmpeg
By Mishari in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2022, 16:23 -
Using MeGUI to convert AC3 and/or DTS to WAV or FLAC
By CountChocula in forum AudioReplies: 4Last Post: 12th Aug 2017, 14:46 -
Mkv convert dts sound into ac3
By fits79 in forum AudioReplies: 5Last Post: 5th Jan 2017, 21:41 -
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 06:17 -
How to convert AC3 True-HD to DTS ?
By Kernell in forum AudioReplies: 15Last Post: 29th May 2016, 21:42
