Results 1 to 30 of 38
    Apr 2010
    London
    Hello
    I am ripping many TV series DVDs all suffer from that terrible technology that someone way back thought and designed called interlacing, it is truly dreadful on today's technology! Oh those phosphor CRTs Tubes !
    Other than spending hours after a 1:1 rip, re-encoding with de interlace options taking even more hours,
    what is the best media hardware player that can play interlaced rip of DVDs correctly without artifacts showing
    is there such a item ??
    Its seem to me no one can design a media player to tick all the boxes and play everything perfectly ?
    will the new ziddo / dune / zappti etc, play media back withou showing the combing artifac of interlacing
    this was a terrible technology method when showing on todays modern equipment
    would rather just rip my DVDs and use the best media player out there that can deal with the best de interlacing
    any help will be much appreciated
  2. ISO images or VIDEO_TS folders?
    Apr 2010
    London
    Hello
    Thanks for the reply
    It can be either as I have ripped to folder but can easily make them iso
    Just really looking for the best de interlace playback
    Regards
    That's a pretty daft statement. So I'll just assume you're taking the piss.
    I play ISOs with my WDTV.
  5. Member DB83's Avatar
    Jul 2007
    Maybe I have been living under a stone for some years.
    But I really thought that 'modern equipment' actually de-interlaced interlaced sources for display. If you get interlacing artefacts I humbly suggest you have not set up your player/tv correctly.
    Apr 2010
    London
    Hi
    Thanks for your replies
    No i'm .... deadly serious!! I hate seeing interlaced crappy images
    it's previous technology that just causes grief and hassle today... The inadequacies of CRTs is the only reason it was used, ok then, but a real pain now.
    though I understand it's better to keep the original rip interlaced in its original format (interlaced), It still needs good de interlacing to trying and hide it / all the artifacts
    VLC does ok
    but I have an older dune media player from about 2012 that shows the interlaced artifacts when playing ripped DVDs, so they look crap
    thus looking to replace and hope to find a new media player that can de interlaced well
    I have also gone through the menu of my sony TV and can not find any options about de interlacing
    so guess I need to rely solely on the media player to deal with this pain in the ass called interlacing !!
    also having the same pain in the ass issues with vhs tapes I have ripped in with my AJA video capture Card
    I hate interlaced images,.,,,,,,
    so back to my original question, can someone please tell me what is the best media player to play and de interlace interlaced content
    Thank you in advance
  7. My old Raspberry Pi 3B with Kodi plays VIDEO_TS folders with good deinterlacing. If you were to consider an RPi you should get the model 4 at this point in time (faster, hardware h.265 decoding, 4K@60p output). Kodi on my cheap (uncertified) Google TV device plays VIDEO_TS folders but its deinterlacing wasn't as good as the RPi -- more buzzing/aliased edges.
    You might want to check out the latest ChromeCast with Google TV (US$50). It can run Kodi, access Windows network (SMB) shares, an external USB drive etc. Apparently it performs very well but I don't know how good its deinterlacing is. The one big problem it has is it only has a single USB port and it's used to power the device. You have to use an external powered USB hub to get power and access an USB drive. See the reviews on youtube.
    Apr 2010
    London
    Hi thanks for the reply and info
    I was considering either another dune or zidoo 1000Pro or the new Zidoo X player when it released
    or anything else in the pro range, just trying to find out what de interlaces the best as I have lots of tv ripped content
    thanks for your info
    appreciated
  9. None of the OP's post makes any sense. Every modern TV set deinterlaces, and they all do a great job.
    If you are seeing deinterlacing artifacts, then you are doing something in a very non-standard way.I have never once, in the ten years I've had my Samsung LCD, seen even one deinterlace artifact despite playing from a laserdisc player, VCR, computer, DVD player, XBox, thumb drive, and pretty much every other source you can name.
    I think you need to describe how the DVD rips are being played (what equipment, and how is it hooked up) in order to get better help with your problem.
    And, BTW, deinterlacing is a brilliant solution to a basic engineering problem and was so good that even when the modern HD specification was formalized almost a quarter century ago, interlacing was included in the spec (1080i). Even today, the same engineering problems are what have kept widespread adoption of 4K (not enough storage space/bandwidth/processing power).
    Mar 2008
    Quite a few examples recently of interlaced rips in mp4/mkv marked as progressive.
    Does the TV /media player still de-interlace? I don't think so.
    Commercial disks being ripped without removing the copy protection?
    But it's all a guess as there is not enough detail, no sample or mediainfo report
  11. Originally Posted by johnmeyer View Post
    I couldn't agree more. I suspect he did more to them besides just "rip". Also, he seems to want to be able to play them on more than just a DVD player. But even media players have deinterlacers.
    It's called a DVD player. Don't you use one to play your DVDs? If so, do they show the interlacing of your 'rips'? Could you provide a short 10-second sample of one of these 'rips' that doesn't play correctly in the players with which you're testing?
    Apr 2010
    London
    Hi guys
    I am doing a 1:1 rip to audio and video folder of the DVDs
    I am using dvdfab and any dvd
    Not doing anything to the quality etc it’s a true lossless rip of the dvd
    The idea is to STOP using my DVD player and purchase a high quality
    Media player
    I already own a dune media player but it’s about 10 years old
    So know they have moved on
    But also have a Sony lcd 42 inch about 10 years old and that does not deal with interlacing well
    Nor does my 55inch Samsung of about 5years ago
    So let’s forget the TVs trying to sort out the interlacing
    does today’s media players deinterlace and
    Sort out these awful dam interlaced artifacts
    Regards
    Mar 2008
    Hi guys
    Media player
    Regards
    Are you trying to convert you 1:1 rip into an mp4/mkv?
    Something like Vidcoder/Handbrake does "decomb" on the fly, not a bad result for somebody who
    doesn't know what they're doing.
    Why don't you post a short clip of one of your encoded files to this thread
    Apr 2010
    London
    thanks for your feedback
    Hi yes ok I can post a sample
    a while back I was trying to convert rips to MP4 using avisynth and some super deinterlace plugin and script.
    but... I don't want to do this, I want to play the original RIP in pristine quality, I should be able to do this surly ?
    I don’t really want to re encode any of the DVD rips
    Would like to leave them native not mp4
    And hopefully choose the right media player to do the de interlacing
    That’s really what I am trying to achieve
    So the interlaced dvd rips look great from the output of the media player
    The same de interlaced quality as someone suggested from a DVD player, but don’t want to use a DVD player
    Want to use a media player but have the same quality playback as if it was on a DVD player
    Don’t want to rip the dvds and then re-encode each one to get rid of the interlaced artifacts
    as this seems a pointless exercise
    What a real pain in the ass this interlacing is......
    Regards
    Apr 2010
    London
    manono
    Wrong..... did not do anything to the rip...
    possibly, my problem is the old dune media player that does not do de interlacing very well !
    thus why I am asking the question ... what is the best Quality media player for perfect de interlacing results ??
    or are they all the same ???
    I am looking to purchase a media player to get over the poor playback on my older dune
    Thanks for any help
  16. Until you provide a clip that has NOT been re-encoded (i.e., it must be a lossless cut from the VOB file) I don't think we can tell what is going on.
    You also need to describe exactly how these VOB files are being played. Reading between your lines, it sounds like you are using a media player on a computer to play the IFO/VOB titles from your DVD rip, and you have the computer connected to the TV set.
    If that is correct, what connection are you using between the computer and the TV set? Composite? Component? HDMI? VGA? This will help determine whether you need to do deinterlacing in the media player (which I would not recommend) or whether the TV set can do it. It would be best to let the TV set handle it because that deinterlacing is handled by hardware & software that is specific to the display. Also, you do not have to remember to turn it on or off, nor do you have to configure it.
    Apr 2010
    London
    Ok so ...
    1) I rip the DVD, Lossless
    2) the aim eventually is to store this image along with hundreds of other lossless dvds / blu ray images on a large 14TB drive in my NAS for use with the media player.
    3) but while ripping I also test / view the RIP using VLC and can see the difference between interlacing enabled / off in VLC
    just trying to find the best media player out there to get the very best reproduction from older interlaced poor quality DVDs
    My current dune media play connects to the TV via HDMI, but as I said earlier, the dune was purchased back in 2010 ish so the newer pro media players like zappti and zidoo have now moved on a graet deal, even the later dune media player and much more advanced than the one I have.
    here is a sample of a 1:1 rip from a DVD with horrid interlacing
    regards
  18. A software DVD player (in a standalone media player) that doesn't deinterlace would be the exception. Except when the player is set up to output 480i or 576i when playing such material. In that case the TV would do the deinterlacing.
    By the way, the RPi and GoogleTV devices I mentioned earlier were connected to their respective TVs with HDMI at 1080p60. So the players were doing the deinterlacing.
    Mar 2008
    Something odd about the source file, doesn't play properly in VLC.
    Try this file, indexed in DGindex and re-encoded
    Apr 2010
    London
    yes agree there is something strange about this file
    I used a program called avidemux to strip it from the DVD image, but don't think it worked very well
    try this, but no audio ?? not sure why
    just trying to find a good little proggy to allow me to strip a small clip from the DVD ripped image without encoding
    regards
    Apr 2010
    London
    try this file
  22. Member
    Mar 2008
    Best way to take a clip from VOB is DGindex. Use the [ and ] to set your clip.
    file/save project and demux video (and it will create an m2v file)
    The second file looks OK, VLC, mpc-be and my TV (played via DLNA) plays it properly, no sign of any combing
  23. Member
    Apr 2010
    London
    thanks
    here is the file using DGindex
    again slow when you turn off interlacing in VLC
    again no audio too ???
  24. DGIndex saves the audio as a separate file. The m2v file is normal interlaced TFF PAL.
  25. Yes, normal, so not what I was suspecting as the reason he has deinterlace problems.
    And MPC-HC deinterlaces it well enough.
  26. Member DB83's Avatar
    Jul 2007
    The original clip played ok for me. I would not describe the interlacing as 'horrid' but normal. With de-interlace invoked it also played fine.
  27. The VOB played fine for me using VLC.
  28. Member
    Apr 2010
    London
    Hi Guys
    thanks for your help
    so several questions please
    1) for the best quality playback, of these old TV interlaced DVD rips on modern media players / TVs
    am I better off re encoding the whole DVD dealing with interlacing etc like in AVISYNTH
    or should I just simply leave as is, and rely on the media player hardware to deal with playback / interlacing from the original files from ripped dvd ?
    2) is there any good software that can cut/crop sections from my DVD rips but without re encoding, so the quality is the same as the original DVD rip, but I just kept the video content between the A/B markers and discard of the rest
    similar to DGindex but that can export video and sound in one video file
    Thanks for any help
  29. Don't re-encode. It is a total waste of time. What do you expect to gain? Re-encoding always degrades the video, and that degradation is permanent.
    This advice is especially true in this case because there is nothing wrong with your video.
  30. Member
    Apr 2010
    London
    Thank you for the reply
    so you are saying keep the original 1:1 DVD Rip folder and the media player should be able to deal with the files and de-interlacing and give the very best quality playback
    I't just my older dune media player that I am looking to replace does not play the DVD rip that well, it's ok back but not great.
    I'm sure newer media player chipsets are much better.
    also is there any good programs to crop a full dvd in to smaller sections with out and re-encoding and quality loss
    thanks
