  1. Hi I have this movie I think its blueray not 100% but it has these folders in it. how do I view it and how do you burn it to DVD
    would anyone here know how to burn it to a dvd I use Ashampoo program to burn DVDs I have just tried imgburn and it says not enough room on disc
  2. You must be new to pc world if you want to Burn 25GIB folder on 4,37 GiB dvd.
  3. Capturing Memories dellsam34's Avatar
    Jan 2016
    That's a BD rip, You need a BD-R blank disc if the rip is under 25GB or a BD-R DL if the rip is above 25GB, Insert the blank disc into the BD drive, open IMGBurn app, Choose hard drive to disc image option and select the folder, IMGBurn will take care of the rest.
    If you don't have a blu-ray drive just get one they are as cheap as DVD drives and they can playback and burn all old discs like CD's and DVD's, BD-R blank media is not expensive either.
  4. Originally Posted by dellsam34 View Post
    Hi many thanks for your reply, But my friend dont have a blue Ray player and dont want to buy one either, is there anyway of converting this BR to say mp4 or a normal DVD
    Jan 2016
    There is but a lot of work, First you have to put all the streams in one single file, then convert the files to mpeg-2 program stream I believe, then from there author a DVD using a DVD authoring program. The easiest way is put the files on 32GB or 64GB flash drive and have him watch them.
  6. Originally Posted by dellsam34 View Post
    Well trouble is this friend is not a close friend just someone who I knew years ago. so cant send them a flash drive as dont know them that much
