Hi guys,
help needed. I bought old VHS player (LG DC368, VHS and DVD player) and I'm trying to connect it to Sony 55" LED KD-55XE8505B, but without success.
I'm using 3*RCA-3*RCA A/V cable, like this: https://www.oomipood.ee/image/cache/catalog/CVGP24300BK20_1-300x300.JPG.
If I put like this:
- yellow cable to VHS "Y" jack and yellow to "Y" TV jack
- red cable to VHS "Pr" jack and red to "R" TV jack
- yellow cable to VHS "Pb" jack and yellow to "L" TV jack
Then I have sound, but no picture. It just says "DVD/VHS player" and it's black and white.
If I connect red and yellow to "R" and "L" jacks in VHS, then the picture is colored (just says "DVD/VHS player"), but no sound.
Use the scart output (euro av1).
https://www.google.de/url?sa=t&source=web&rct=j&url=https://manualzz.com/doc/49411360/...=1606655198897 -
It is amazing that you have sound. YPRPB is the designation for component video. If you have component video out of the VHS/DVD combo, then if the TV also has YPRPB inputs, you should use three of the RCA cables to connect the video and then use two more RCA cables to connect the audio.
If instead you only have a composite (yellow) input on the TV, you can usually connect just the Y connections, but then look around on the back of your VHS/DVD player for two more RCA jacks for the audio and use those. -
Hi, I am trying to get a VHS tape to play on an Emerson EWD2204 VCR/CD player. I can easily play dvds. When I try to play a VHS tape, the tape stops and I get the message "No Signal". I have tried taking the VHS tape and placing a ballpoint pin into the 1/4 inch hole between the two spools and manually turning the spools. Why? I read that sometimes they get stuck and by releasing the lock and manually turning the spools my VHS tape may play. They recommended FF through the tape and then rewind. I never had a chance to hit FF before the tape stopped and gave the "No Signal" message. Does anyone have any suggestions? I am connecting to a Sceptre X405BV TV via RCA cables Red, White, and Yellow.
I just want to mention that I do not have cable, satellite or an antenna. No TV broadcasts. Only use id for DVDs and VHS.
sounds like the vhs portion of the player is dead. get something else. emerson was the bottom of the barrel in quality.
Your TV can either have a special breakout cable which one side has red/white/yellow and the other side have 3.5mm jack that connects to a yellow female jack on the back of your TV, OR it uses Y of the Y/Pb/Pr for yellow composite and red and white for audio that connects to the red and white of the VCR. Your TV may have both.
Some TV's are mono so you can only connect one audio channel, like this:
https://www.sony.com/electronics/support/articles/00150369Last edited by dellsam34; 6th Dec 2020 at 19:32.
Some TVs you have to adjust the video green/yellow connector to composite mode from component mode in the video setup menu.
AvsPmod - can't get it to work properly
By pooksahib in forum Video ConversionReplies: 9Last Post: 5th Sep 2021, 06:33 -
SubRip - Version: 1.57.0 Beta Do Not Work Properly
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 10th Sep 2018, 21:19 -
CCleaner - Does it Work on Windows 10 Properly?
By devilcoelhodog in forum ComputerReplies: 5Last Post: 8th Jun 2017, 04:21 -
ADVC Mini doesn't work properly
By keyboardboy in forum MacReplies: 32Last Post: 1st Dec 2016, 23:23
