  1. Hello,
    I need to trim some videos with Avidemux, the problem is that the length between each keyframe is about 10 seconds, I want to shorten that to about 1 second.
    Here is a screenshot if you don't understand: https://imgur.com/a/YV7nr9t
    In the video below the length between each keyframe is about 2 seconds while the video above is over 10 seconds.
    Thanks.
  2. Encode with shorter GOPs.
  3. Originally Posted by jagabo View Post
    How do you do that with handbrake?.
  4. It depends on the encoder you're using. With x264 you enter keyint=xx in the Extra Options box -- where xx is the GOP size (distance between key frames). If your video is 24 fps and you want one second between key frames then you want to enter keyint=24.
    A little more info: https://forum.videohelp.com/threads/391526-Handbrake-GOP-setting#post2537934
  5. Originally Posted by jagabo View Post
    Thanks.
