Hey all, I'm authoring Blu-rays using Premiere CS6 (usually just adding company logos and bumpers to the front of a feature prores), then dynamic link to Encore (autoplay... no bells, no whistles). Simple enough. The one issue that appears repeatedly is stray frames: a single frame from earlier or later in the film appearing randomly in a different scene. I'd say it is happening as often as 1/3 of the time, forcing me to redo the whole project.
Adobe's only advice seems to be clearing the media cache (which I do) and/or a reboot (which I do), but this has maybe a 50/50 chance of helping, in my experience. The tedious part of all of this is not re-authoring. I have no problem doing that as needed. I want to avoid QCing the film 2, 3, 4 times just to find one stray frame an hour into it.
Is there a program that can do this for me? Maybe some functionality in ffmpeg to scan the stream for "scenes" shorter than X frames long? We tested Interra's BATON system, which can do this, but in the covid theatrical world we simply can't afford that product.
Thanks in advance for any suggestions.
Results 1 to 1 of 1
BRD: Joey aka Making Contact
By Madz in forum Blu-ray RippingReplies: 1Last Post: 2nd Aug 2020, 05:44 -
Making MKV from multiple BRD playlists without duplicating m2ts files
By TkerThor in forum Blu-ray RippingReplies: 0Last Post: 28th May 2020, 00:59 -
Patch encoder to force P-Frames to only reference I-Frames
By zombiitv in forum ProgrammingReplies: 1Last Post: 9th Sep 2019, 22:51 -
Can I force ffmpeg to transcode 59.94 frames to display at 25 frames per se
By oduodui in forum EditingReplies: 4Last Post: 28th Apr 2018, 10:24 -
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 17:43
