I don't know where should I post it so I posted it here.
Anw, I'm using MadVR on PotPlayer with LAVFilters to make the video play in 60FPS but it seems that they are not playing at 60FPS.
I tried swapping renderer between "Auto" and "MadVR" and I didn't notice any difference.
I don't know too, I'm still not sure. Maybe I just got accustomed to playing 60FPS videos.
I tried playing this video : https://www.youtube.com/watch?v=TVtoxUohG5E (downloaded it and play it on PotPlayer) it doesn't play on 60FPS, I mean visually, because PotPlayer reports that it is playing at 60~ FPS when I am using MadVR as renderer. But when I switch renderer to "auto", it reports as playing at 24FPS but visually there's no difference.
Here are my PotPlayer settings:
https://pasteboard.co/JBUFomj.png
https://pasteboard.co/JBUGscg.png
https://pasteboard.co/JBUHzc7.png
https://pasteboard.co/JBUHVOw.png
https://pasteboard.co/JBUIbbk.png
https://pasteboard.co/JBUIoXy.png
https://pasteboard.co/JBUID0u.png
MadVR settings:
https://pasteboard.co/JBUKdUQ.png
https://pasteboard.co/JBUKqQl.png
https://pasteboard.co/JBUKHdu.png
https://pasteboard.co/JBUN1Az.png
https://pasteboard.co/JBUNdc5.png
https://pasteboard.co/JBUNvFb.png
https://pasteboard.co/JBUNRbH.png
https://pasteboard.co/JBUO0rS.png
https://pasteboard.co/JBUO8E3.png
https://pasteboard.co/JBUOhSK.png
https://pasteboard.co/JBUOpNP.png
https://pasteboard.co/JBUOBl6.png
https://pasteboard.co/JBUOJGz.png
https://pasteboard.co/JBUORAO.png
https://pasteboard.co/JBUP0Yz.png
Any help would be much appreciated!
I tried inserting an image through link but it doesn't display anything. My apologies!
Are you sure the video you downloaded is 60fps ? Check this with mediainfo.
https://pasteboard.co/JC2gmgY.png
The video is 24fps. But it was intended. Because what I want to test if MadVR is really doing 24fps to 60fps. Am I missing something?
What should I do with bShaders? I'm kindly new to this. Back then I was using SVP but it was too heavy for my CPU that whatever settings I get, it stutters. Causing unsynced A/V.
I just found out this MadVR + LAVFilters that it makes 60fps videos. That's what I thought. Or am I missing something? Thank you again for your reply! -
I don't use PotPlayer or MadVR or motion interpolation. You would likely get better answers there: https://forum.doom9.org/showthread.php?t=146228
I did try SVP a while ago and my conclusion was that native 60fps capture was superior and less hassle (and that I would only ever want high framerate for the video contents where it makes sense such as Sports, otherwise regular 24/30fps is fine).
Shaders can be used to do realtime gpu processing in video players. -
I see. I'll try asking there too but it would take 5 days since they required the account should be 5 days old before posting/replying. :3
True but the topic has been discussed recently in the referenced thread.
PotPlayer - How to use MadVR?
By jackuars in forum Software PlayingReplies: 49Last Post: 3rd Dec 2021, 17:20 -
MadVR, MPC-HC, PotPlayer questions
By holycow in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2020, 21:14 -
Potplayer + MADVR, is 10-bit Possible?
By vanbrocklin in forum Software PlayingReplies: 1Last Post: 11th Mar 2020, 06:52 -
Saving current frame w/ Potplayer + madVR, not saving madVR effects
By LJay in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2017, 15:14 -
Open MadVR in PotPlayer 32 bit
By loninappleton in forum Software PlayingReplies: 9Last Post: 9th Apr 2017, 23:19
