I would like to render my recent project in X264. I would like to keep original properties of the files, so similar quality, frame size, etc. Could you help creating an optimal command line for it? My computer is not extremely powerful, has i5-3210M with Intel HD4000 GPU.
I have attached a sample from the source.
The file details from Mediainfo:
Please be aware of that though Mediainfo detects the video as Interlaced 50i, in fact it is Progressive 25p!!!
Thank you in advance!Code:General ID : 1 (0x1) Complete name : C:\Users\bencuri\Desktop\sample.ts Format : MPEG-TS File size : 28.1 MiB Duration : 10 s 40 ms Overall bit rate mode : Variable Overall bit rate : 23.4 Mb/s Maximum Overall bit rate : 35.5 Mb/s Recorded date : 2011-09-09 17:48:02+01:00 Writing application : Canon Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 2 frames Format settings, GOP : M=3, N=12 Codec ID : 27 Duration : 10 s 0 ms Bit rate mode : Variable Bit rate : 22.0 Mb/s Maximum bit rate : 22.7 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.424 Stream size : 26.2 MiB (93%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 9 s 920 ms Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 310 KiB (1%) Service kind : Complete Main
Use MKVtoolnix to create an MKV form your .ts file
Create a simple avs script like this:
Open a cmd prompt and run x264 like this:Code:lwlibavvideosource("C:\pathto\sample.mkv") assumefps(25)
Or use a GUI like Virtualdub2Code:"c:\pathto\x264.exe" --preset "faster" --crf 20 --output "c:\pathto\new.mkv" "c:\pathto\input_avs"
Help - How encoding with Variable Frame Rate using x264 command line.
By Kuronoe in forum Newbie / General discussionsReplies: 7Last Post: 25th Feb 2020, 10:55 -
[SOLVED] PotPlayer command line - open new video in same window
By nitzi in forum Software PlayingReplies: 6Last Post: 6th Aug 2018, 19:54 -
command line util that returns video file info?
By wallywalters in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2017, 20:57 -
confused on x264 command line. Help needed!
By synnchan in forum Newbie / General discussionsReplies: 3Last Post: 30th Oct 2016, 07:13 -
x264 Command Line Settings For Downconverting HD To SD For DVD Playback
By LouieChuckyMerry in forum Blu-ray RippingReplies: 6Last Post: 18th Jul 2016, 08:51
