Hello.
Many, and I mean many, like 10, years ago I bought a concert DVD that had one chapter in the wrong place, it started in the middle of a song, so I remember as it was yesterday, I copied the DVD to PC and found a software that could edit chapetr point of the DVD, I corrected it, saved and ripped the audio based on chapter starts.
Now may years later I have the same problem, the DVD has a concert, but 3 chapetrs are two songs in one chapter, I want to split them, but I have no luck finding that old software also no luck finding any relevant topic here, I tried ifoedit, but nothing is editable here, I tried demuxing and remuxing to VOB files and replacing them in the VIDEO_TS folder, but it made more than half titles disappear in DVD Audio Extractor.
So in short, how can I edit those chapters, based on the timecodes, as I had prepared timcodes for every chapetr point I need (not nessesarily I-frame accurate, so it would be nice, of the program could adjust them accordngly) without authoring a whole DVD, it's a DVD9 with 11 titles and I need to correct only one.
Are you culturally "locked in" to playing on a standalone DVD as a disc? If not why not make MKV files (no loss of quality and quick) that you can insert chapter points wherever. MakeMKV is the program to use.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I am locked in by DVD Audio Extractor, I put a DVD folder there and it extracts concerts to WAVs based on chapters and the chapters 2-in-1 and I want songs in seperate wavs. It doesn't accept mkvs.
You can create new chapter points using VobBlanker. Here's a guide:
http://download.videohelp.com/jsoto/guides/VobBlanker/splitting_cells/index.htm -
I have no idea what any of that means. Chapters can only be created at GOP boundaries. A scene change creates a new GOP. Therefore, you can create a new chapter at a scene change. If you know where that song changeover occurs in the DVD, you should have no problem at all finding that scene change and creating a new chapter.
Another way is to demux using PGCDemux, adding the new chapter point to the Celltimes.txt it gives you, You do that by 29.97fps frame number. And then remux using Muxman. More work, though. -
What what means? Frame number? I know where chapters can be created, hence I wrote about it in the first place, "it would be nice, of the program could adjust them accordngly" from the input absolute frame number to the "legal" I-frame.
I have tried PGC, demuxed it, edited chapter point and remuxed it in Muxman, then I opened DVD AE and lo and beold titles were all messed up, from 11 titles only 5 were shown and not the one I edited.
How to reencode a file from a certain point without also reencoding the pre
By coltson in forum Video ConversionReplies: 1Last Post: 2nd Oct 2020, 20:12 -
Pre-Amp For Audio?
By cornemuse in forum AudioReplies: 4Last Post: 14th Feb 2020, 09:58 -
How to change a video made in time lapse to normal speed?
By TeNSoR in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2018, 07:16 -
Triva question: How did Pre-CSS crack DVD copying work?
By lingyi in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2017, 02:18 -
Importing Chapter Menus/Chapter Markers in Xmedia Recode
By Alexp120 in forum Video ConversionReplies: 0Last Post: 29th Feb 2016, 17:37
