I have a video file without sound and a stereo audio file. Video is several times longer than audio. I'd like to create a background sound which starts from 2 second silence, then trim silence of the audio at both ends and duplicate trimmed audio several times to the end of the video.
I found how to trim audio:
And how to create silence:Code:ffmpeg -y -i audio.wav -af silenceremove=start_periods=1:start_threshold=-75dB,areverse,silenceremove=start_periods=1:start_threshold=-75dB,areverse trimmed_audio.wav
How can I duplicate the audio, combine it with the video (c:v copy) and add an audio fade-out at the end?Code:ffmpeg -y -f lavfi -i anullsrc=channel_layout=stereo:sample_rate=48000:duration=2 silence.wav
If you are not careful to include fade-ins and fade-outs, your aggregate file will have "clicks" at every edit/loop point.
Scott -
Every edit/loop point will start at less than -75db RMS. You won't hear anything.
But it's a good idea to add an audio fade-out at the end.Last edited by qo4on; 24th Nov 2020 at 12:24.
ffmpeg - create video from scrolling image
By M00nsp3ll in forum Newbie / General discussionsReplies: 0Last Post: 7th Apr 2020, 15:27 -
Create a Few Seconds Video preview Using Ffmpeg
By dexterfox44 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2020, 06:49 -
How do I use ffmpeg to create the highest quality animated gifs from video
By Bruce Banner in forum EditingReplies: 13Last Post: 11th May 2019, 00:26 -
FFMPEG: create a transparent background with lavfi?
By Taapo in forum Video ConversionReplies: 1Last Post: 20th Sep 2017, 09:07 -
how to create 3s picture pause at 30s intervals of a video with ffmpeg
By rey1 in forum EditingReplies: 2Last Post: 20th May 2016, 09:10
