Hello,
after authoring a Blu-ray with tsMuxeR GUI 2.6.12 is only 1 of 3 subtitle languages displayed correctly in Macgo Mac Blu-ray Player.
When I play the same Blu-ray ISO with VLC all languages are displayed correctly.
The files are all .srt and the correct languages are selected in tsMuxeR GUI.
Subtitle Edit 3.5.18 shows me the following encodings:
- German - UTF-8 with BOM
- English - 28591: Westeurope
- French - 1200: Unicode
Only the second subtitles language is shown correctly as "English" the two others are displayed as "Unknown language".
Do you got a hint for me? Which is the standard encoding I have to choose for blu-rays?
Thanks in advance,
BenJamin
	It's the authoring program that determines the subtitle settings so you have to choose another program that will display what you want.I use tmpg authoring works 6 for authoring but others might tell you other programs that work for them. I think,therefore i am a hamster.
	@BenJamin
 I don't work srt to bluray your way, but maybe your issues are solved in more recent versions of tsMuxer?
 Since you are familiar with SubtitleEdit, you can consider to do this:
 Open the srt's in SubtitleEdit and go File --> Export --> Blu-ray SUP. It gives you a bunch of controls on how & where the subtitles are going to look like.
 It's important to choose the right Video resolution and Framerate. I find that SubtitleEdit does nice graphics with SUP.
 When done, you can import these created *.SUP files into tsMuxer. You must of course tag them with the proper language. Works always for me.
  Any Software to Add Subtitles to Foreign Language Films?By pone44 in forum SubtitleReplies: 1Last Post: 5th May 2020, 07:19
  MPC-BE + LAV Splitter - Subtitles Always DisplayedBy Clifton27 in forum Software PlayingReplies: 2Last Post: 24th Mar 2020, 08:20
  How can i strip the Subtitles which are only displayed on the top screen?By Knackstiefel in forum SubtitleReplies: 7Last Post: 4th Nov 2018, 17:27
  subtitles for foreign language scenesBy njitgrad in forum Video ConversionReplies: 14Last Post: 21st Feb 2018, 11:04
  Creating Subtitles in Hebrew Language - How to do it properly?By devilcoelhodog in forum SubtitleReplies: 3Last Post: 16th Jun 2016, 18:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
