So, I'm having the strangest bug of 2020 here. All of a sudden, both MPC-HC and VLC only show a black image when playing videos. Windows Media Player is not affected.
I have another parallel installation of MPC-HC (another folder), which worked for a while until it also stopped working in the same way - black image, only audio.
I can take screenshots and they work fine.
All video formats seem to be affected. CD covers (tag images) are shown normally.
Trying to view the video in fullscreen will not work, it will glitch out (I keep seing the window).
Playback on admin account is the same.
Deactivating ffdshow (which I'm using as default) did not change anything, but VLC does not rely on ffdshow either. Also, it was working fine until now.
I recently updated to Windows 10 20H2 (x64), although the black screen thingy occurred somewhat later, not right after the update.
Graphics card is an Nvidia GTX 970. Updating (which also means reinstalling) the graphics driver did not change anything.
	I'm OddTheodora. I'm open for everyone, and I'm for free.
	Yes! (MPC-HC settings: Playback > Output > Video Renderer). MadVR was still selected, even though I had uninstalled it recently. must have messed up the settings. For some reason though, playback wasn't affected right away (??). I'm not sure what was selected before that or what is the default here.
 Thanks, jagabo! I'm OddTheodora. I'm open for everyone, and I'm for free. I'm OddTheodora. I'm open for everyone, and I'm for free.
	It's called the video output or renderer. In MPC-HC the default is EVR-CP which is dx9 based. Changing the video renderer always requires restarting the player. The Mpc-hc renderer shouldn't affect VLC though.
 if you detect a problem, it's always worth clean restarting your machine before reporting a bug as the issue may not be reproducible.
 In your case, a simple mpc-hc settings reset would have solved the problem. You can do this without losing your saved settings by doing the reset while using a new mpc.ini settings file.
  MPC and VLC display video differently by colorspace and component rangeBy vice2 in forum Software PlayingReplies: 4Last Post: 9th Aug 2019, 15:31
  Black/green screen playing HW accelerated video (VLC, MPC-HC)By Behemot in forum Software PlayingReplies: 5Last Post: 16th Jun 2018, 09:06
  Please look at this video and see why it won't play in vlc (plays in MPC)By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2017, 17:31
  DVD only playing in MPC, not working in VLC or anything elseBy twinaleblood in forum Video ConversionReplies: 1Last Post: 4th Jul 2016, 03:59
  Video Audio not working in MPC-HCBy dr-love55 in forum ComputerReplies: 3Last Post: 21st Dec 2015, 21:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
