I wasn't able to find any other posts that cover off this.
When I load a bunch of files into PotPlayer it adds them to the playlist, which is what I want, but it does something strange with the files that are split into multiple parts greater than 9. For example I might have a large file split into 14 parts: "Large File - 1of14.mp4", "Large File - 2of14.mp4" ... "Large File - 14of14.mp4".
Windows correctly puts them in order, but PotPlayer playlist sorts them strictly by the first digit (10, 11, 12, 13, 14, 1, 2, 3, 4 etc). I can right click the playlist and select to either sort by name or title and it puts them in the correct order, but not by default.
I can change all my files to add a zero before the single digit numbers, but the frustrating thing is that PotPlayer knows how to sort the files properly, but just won't do it.
Anyone come accross this issue before?
				Results 1 to 1 of 1
  PotPlayer Add all files to playlistBy Emanuel in forum Software PlayingReplies: 1Last Post: 22nd Sep 2019, 09:47
  How do I completely disable the playlist in PotPlayer?By Kizzume in forum Software PlayingReplies: 5Last Post: 14th Sep 2019, 20:20
  PotPlayer playlist confusionBy TBacker in forum Software PlayingReplies: 0Last Post: 16th Jul 2018, 00:04
  Need Help Change Default Title/Global Title to the same one as file nameBy Inoyama in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2018, 17:21
  PotPlayer: Advancing the Playlist issueBy lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 14:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
