    Nov 2020
    Bulgaria
    Hello!
    I have this file with .bin extension thats a recording from my Phillips Smart TV. I am wondering if i can play it on my PC too. When i try to open it with VCL it detects the right length of the recording, but there is no audio and video, just black screen. I checked the file with mediainfo and i got this output:
    General
    Complete name                      1605783419-66.0-1605783419_0000.bin
    Format                                   : BDAV
    Format/Info                              : Blu-ray Video
    File size                                : 241 MiB
    Duration                                 : 13 min 1 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 586 kb/s
    FileExtension_Invalid                    : m2ts mts ssif
    Video
    Menu ID                                  : 1015 (0x3F7)
    Format                                   : MPEG Video
    Format version                           : Version 2
    Codec ID                                 : 2
    Maximum bit rate                         : 6 175 kb/s
    Frame rate                               : 25.000 FPS
    Encryption                               : Encrypted
    Audio
    Format                                   : MPEG Audio
    Format profile                           : Layer 2
    Codec ID                                 : 4
    Bit rate mode                            : Constant
    Maximum bit rate                         : 216 kb/s
    Language                                 : Bulgarian
    Menu
    List                                     : 848 (0x350) (MPEG Video) / 849 (0x351) (MPEG Audio, Bulgarian)
    Language                                 :  / Bulgarian
    Maximum bit rate                         : 6390400
    So my question is is there a way to play this or its encrypted so i can play it only on the TV?
  2. Encryption : Encrypted
    This says all. No luck to open it outside your smart TV.
    Nov 2020
    Bulgaria
    So there isnt some fancy way to bypass this encryption?
    Mar 2011
    Nova Scotia, Canada
    No. That's what encryption is supposed to do.
