Here is my feeble attempt to save us all from reading the same questions day after day after day...
So, following is a few commonly asked questions on the board, along with links to posts with advice that should help:
1) Illegal floating decimal point calculation order
http://forum.vcdhelp.com/viewtopic.php?t=87438&highlight=illegal+floating+decimal+point
2) I can't save my wav from my divx avi in virtualdub
http://forum.vcdhelp.com/viewtopic.php?t=83221&highlight=ac3+divx
3) Audio is in sync with video on source, but not after encoding
http://forum.vcdhelp.com/viewtopic.php?t=88270&highlight=audio+sync
5) How do I get rid of that annoying hissing sound in my movie?
http://forum.vcdhelp.com/viewtopic.php?t=88331&highlight=hiss
6) I can play my file in media player, but TMPG gives only black screen
http://forum.vcdhelp.com/viewtopic.php?t=86209&highlight=direct+show+reader
and if these links don't help, try the search button...it actually worksmake sure to try your search using a few different terms if you don't get an answer on your first search before posting a new topic.
Great post! except aud synch. The fastest and easiest is tmpgenc source range audio gap correct. If aud is ahead of vid then change audio gap correct numbers to negative and if vid is ahead of audio use positive numbers. Just be sure to make a 1-2 minute clip and check to see if in synch or change numbers until it is in synch. It's just that easy
I'm adding another tip here... I'm new to video encoding, and it took me hours to find out the solution to a problem I've had, so I post it here to help other people experiencing the same problem
4) After encoding a DivX to VCD, I get a black screen with audio only
http://forum.vcdhelp.com/viewtopic.php?t=90471- A Life? Cool! Where can I download one of those from?
- I have a dream: 1,000,000,000,000 bytes free.
- The box said: 'install on Windows XP, 2003 or better'. So I installed it on Linux.
- Windows is NOT a virus. Viruses DO something -
updated 5/8/02:
added link for audio hiss removal
thanks to SimoBk for his input on encoding from DivX sources
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Common questions and answers.
By Faustus in forum DVD RippingReplies: 31Last Post: 27th Feb 2008, 06:21 -
Do I own an illegal dvd ? and some questions !
By bradford in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2007, 03:27
