What program do i use? where can i get it? how do i do it? where do i get this discjuggler or whatever? everytime i try a direct drive to drive copy it freezes up. thanks!
-Eric
Clone cd will make an exact copy of just about any cd. it doesn't support all the cr rwritable drives so you might have trouble there but if it works with your burner then that is what i would htry. Do a search for clone cd and i am sure you will find it.
Hi,
You can find CloneCD here :
http://www.elby.de/CloneCD/english/index.htm
Check the supported writers to see if your burner is supported.
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success !
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 03:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 01:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
