I'm trying to join together four Y4M files.
I tried using both of the ffmpeg methods on this page:
http://trac.ffmpeg.org/wiki/Concatenate
Both times, I get this error:
How can I join them using my Mac please? Thanks in advance.Code:[yuv4mpegpipe @ 0x7fce28809400] ERROR: Codec not supported. Could not write header for output file #0 (incorrect codec parameters ?): Invalid data found when processing input
Using "cat" to crudely join the files doesn't work either. Only the first clip plays.
A full command line example of your first try would have been useful. I guess explicitly stating formats (yuv4mpegpipe) may have helped. But the position of parameters is important.
PS: Tested and failed as well, so far...
Solution: omit the "-c copy"; concatenating raw formats does not need codec actions to be specified, they are not supported for such formats.
Thanks to JEEB on IRCCode:ffmpeg -f concat -i list.txt -f yuv4mpegpipe out.y4m
"Raw" recovery of video files (file carving, signature search)
By abolibibelot in forum ComputerReplies: 1Last Post: 13th Aug 2021, 10:38 -
how do i open a raw disc/ RAW format on a computer
By elm in forum DVB / IPTVReplies: 2Last Post: 9th Mar 2020, 18:33 -
How to join batch video files?
By iKron in forum Video ConversionReplies: 7Last Post: 9th Sep 2018, 13:19 -
How can I join 2 video files to 'combine' quality?
By YeshyyyK in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2016, 13:54 -
SATA HDD in IDE computer! Video files missing? Sata HDD now RAW!
By visionman in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2015, 12:35
