hi
i have 8 mp4 files, that i want to convert to blu ray folder and burn to watch on blu ray player..
should i just add file 1, add file 2 so on?
or add file 1, then join file 2, so on?
is there a way to get a basic menu sort of opt 1 play all and then play file 1, back to menu then play file 2?
also could i clip the crap out of the files? ie the last 3 minutes of the file? and then the clip the intro on the next, so on? so it is like a film?
thx
That's not even close to how it works.
To do what you want to do - especially the menu and the clip play ordering - you must use a legit Bluray authoring app and compile that way. And there are no freeware versions of this.
Also beware: your mp4s may not be Bluray-legal format and so you might need to re-encode regardless. Obvs, you will be wanting to encode using a tool that is known to output BD-compliant material.
Extracting a Blu-ray menu
By koberulz in forum Newbie / General discussionsReplies: 34Last Post: 14th Jul 2020, 11:00 -
Blu-ray Menu Screenshots: Is there any hope?
By User897 in forum Blu-ray RippingReplies: 17Last Post: 30th Aug 2019, 09:29 -
Is there a way to take a screencap of a blu-ray menu?
By Hatteras in forum Newbie / General discussionsReplies: 5Last Post: 4th Feb 2018, 20:30 -
TMPGEnc Authoring 5 Blu Ray Menu Help
By jimmyboyl in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Mar 2017, 18:18 -
Tsmuxer Newb: mkv to blu-ray disc?
By 70runner in forum Video ConversionReplies: 10Last Post: 19th Jan 2016, 16:43
