Hi.
So I remuxed several PAL dvds using MakeMKV because I want to restore the files to their proper speed (get rid of PAL speed-up). I've done it successfully with AVC codec files before, but those not being re-encoded, the format is MPEG Video.
I've slowed down the audio and used this command line to batch convert the files to 23.976 fps:
It works fine, they play properly at the new frame rate on my computer. The issue is when I play the files directly on my smart TV, the playback is jerky, I've tried two Blu-ray players as well and it's the same.for %%F in (*.mkv) do ( "C:\Program Files\MKVToolNix\mkvmerge.exe" --ui-language fr --output "New\%%~nF.mkv" --no-audio --language 0:eng --default-duration 0:24000/1001p --fix-bitstream-timing-information 0:1 --language 0:eng "%%~nxF" "%%~nF.ac3" --track-order 0:0,1:0 )
The playback is smooth with MKV files with AVC spec, so I'm assuming MPEG Video is trickier to convert without re-encoding? (the files are also flagged as interlaced). Does anyone have a solution?
Here's the mediainfo for one file (after conversion to new frame rate):
Thank you.General
Unique ID : 4641677125443864067923835415291516482 (0x37DF459E71A083B9B8445F6AD8C5642)
Complete name : E:\Download\\New\S03E03 - The Bus Stops Here (1).mkv
Format : Matroska
Format version : Version 4
File size : 1.91 GiB
Duration : 46 min 26 s
Overall bit rate : 5 886 kb/s
Encoded date : UTC 2020-10-13 22:44:49
Writing application : mkvmerge v37.0.0 ('Leave It') 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Format settings, picture struc : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate mode : Variable
Bit rate : 5 692 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.572
Time code of first frame : 01:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first fram : Closed
Stream size : 1.85 GiB (97%)
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Duration : 46 min 24 s
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 63.7 MiB (3%)
Service kind : Complete Main
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapitre 01
00:02:09.120 : en:Chapitre 02
00:08:44.640 : en:Chapitre 03
00:18:44.640 : en:Chapitre 04
00:28:44.640 : en:Chapitre 05
00:38:44.640 : en:Chapitre 06
00:44:00.960 : en:Chapitre 07
00:44:30.800 : en:Chapitre 08
Closed Thread
Please do not open another thread on a subject you already started,this thread is closed,please resume here-
https://forum.videohelp.com/threads/399150-Batch-convert-mkv-files-to-different-frame-rateI think,therefore i am a hamster.
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 02:50 -
Converting .TS with variable frame rate to .MKV
By MeltdownSpectre in forum Video ConversionReplies: 3Last Post: 4th Jun 2020, 02:11 -
Are all movies and videos are made using a fixed frame rate or not? If not,
By jraju in forum Newbie / General discussionsReplies: 13Last Post: 17th Jan 2020, 08:10 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 05:01 -
Variable frame rate into constant frame rate without re-encoding
By DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 11:05
