That's about old videos wich i want to make a clip with (320x240 like). All those on the Resident Evil PsX discs, i ripped with jPSXdec at highest quality ( RGB lanczos, that i choosed despite reading manual about AviSynth filtering).
jPSXdec manual :
https://drive.google.com/file/d/1MpKBfoO1-XYVdd6rvGUTMrqQyJQKIBMq/view?usp=sharing
The FMV game intro found on the French (like me) and German discs is in color for director's "uncut" version. This is "the" only file (i think this will be, FR & GE needed it !!) that needed a/v sync option in jPSXdec (manual explains how PSX movies start with audio sync). Didn't checked all files at this time.
There is also Jap audio on a special disc (called "Complete disc").
With all those different version regions discs i found some variants (music, scenes, sounds, voices...).... i'd like to make a comlplete A/V edit with all that stuff.
I have :
VideoPad 7
AviSynth+ : AVSinfoTool, AvsPmod, Zs_RF_Shared , QTGMC, FFTW, TFM, DGDecode, Decomb, EEDI2+3 (since my first topic "3 A.M, Taxis pour cible")
VirtualDub2
AviDemux
MeGui x86
Handbrake
USEac3To
XMPlay
Mpc-Hc
Mpc-Be
SMPlayer (mpv)
Vlc.
I know nothing with VideoPad, it's an advanced tool to me.
PsX videos STR format :
https://github.com/m35/jpsxdec/blob/readme/jpsxdec/PlayStation1_STR_format.txt
Video made on ModDb :
https://www.moddb.com/games/resident-evil/downloads/resident-evil-1-enhanced-fmv
From 320x240p 15fps to 1920x1440p True 60fps using Machine Learning and Interpolation=interpolated 30fps.
https://www.reddit.com/r/residentevil/comments/eyms8z/i_upscaled_the_original_resident...evil_psx_1996/
I just extracted movies from PSX discs at this time, will ask help when needed.
First recommandation, as i used the highest quality possible with RGB and Lanczos, i want keep it as this, but it's 783Mo for 3min47sec, is Lagarith (also RGB24, as input) doing that well ? It gives a 227Mo file.
First exemple of a wanted edit, add papernews transparency from cut version frames, to uncut version :
https://drive.google.com/file/d/1Bve2mC6W9LnHe9ZvQX8fmrL1yiCQ4wdU/view?usp=sharing
Papernews censor in place of zombies
https://drive.google.com/file/d/1svak1PqWexNyg9FHGQ_MlmeHfz5Hahcr/view?usp=sharing
Jap dub
https://drive.google.com/file/d/1KbzueB8AVrlKW1qWukEbfziZMHB1iobD/view?usp=sharing
Last edited by KlemNT; 30th Nov 2020 at 09:26. Reason: vut version = cut version _ fmv link = NoRGButLagarith
The files kept by discs :
French v1.0 =
Capcom logo v1
Intro B&W ccensored
French Director Cut =
Capcom logo v2
Zombie eat Keneth (sound only)
Hunter goes downstair open door (sound only)
Shark in water (sound only)
Fountain emptyingg water (door sound only)
Mansion explosion (sound only)
Endings 2-8
Menu - Resident Evil
Intro Colored uncut
Logo Virgin (megastore)
USA Dual-Schock =
Zombie eat Keneth (sound only) / DS zik
Endings 2-8 / DS zik
JAP v1.1 =
Intro B&W uncut / Cast zik (i've got a shotgun)
JAP Director Cut =
Zombie eat Keneth - uncut (sound only)
Ending 1 - uncut
Menu - Bio Hazard
Intro B&W uncut
JAP Dual-Schock =
Zombie eat Keneth - uncut (sound only) / DS zik
Hunter goes downstair open door (sound only) / DS zik
Endings 1 - uncut / DS zik
Intro B&W uncut / DS zik (i've got a shotgun)
JAP Complete CD (DS cd2) =
Intro B&W uncut / DS zik - Jap voice dub
I think i will update that just a little
Hello,
i need to find a solution to make AviDemux work better with 4K video, audio plays while video stutter, i can use it one second max and it's annoying, it doesn't seek very well also in pause mode.
I'm doing something with RE2 Apokalipse X265 4K movies.
EDIT : at least i have good chance, i use four audios and it has exactly this option
VFF, VF2 (not good, newer), VFQ, VO
II : fiXed
III : not synced a/v, but video advances better, play/pause is instantany !!! Async occurs from the 2nd second.
DXVA2
IV : fixedLast edited by KlemNT; 15th Dec 2020 at 17:54.
Create a function in Avisynth to apply a logo on a clip
By kaskaļ in forum EditingReplies: 1Last Post: 9th Apr 2020, 10:03 -
x264 conversion poor quality for some sources
By tony95 in forum Video ConversionReplies: 13Last Post: 2nd Oct 2019, 02:39 -
Create a video-level image from a clip
By barabba2005 in forum Video ConversionReplies: 0Last Post: 9th Nov 2017, 09:28 -
Enhancing PSX FMV's with Avisynth
By SecretAshe in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2016, 18:06 -
Create Random Video Montage Clip from several imported videos ?
By draven1968 in forum EditingReplies: 2Last Post: 21st May 2016, 12:19
