good evening. is it possible to edit DTS and DTS-HD with the Audacity program? if so how can you export in the same format?
first you'd have to use something like foobar with the dts plugin to export the dts into 6 wav files. then edit in audacity. then use an encoder like surcode dts to create a new dts file. https://www.bhphotovideo.com/c/product/439464-REG/Minnetonka_SDVW_SurCode_DVD_DTS.html
FWIW: Surcode DTS Encoder is outdated
Use the freeware ffdcaenc for vanilla DTS or the official /certified Monster Audio Suite if you need DTS-HD.
"Programmers are human-shaped machines that transform alcohol into bugs."
Any sound and mostly dts & dts-hd to ac3
By fits79 in forum AudioReplies: 42Last Post: 23rd May 2024, 00:43 -
Edit DTS in audacity with 6 channels
By villaquien in forum EditingReplies: 5Last Post: 12th Apr 2024, 21:19 -
Are there any pros in keeping a DTS audio track if a DTS-HD is available?
By alexd15 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Feb 2019, 05:22 -
How to convert DTS-HD / HDMA With bitrate 1509kbps to DTS 755kbps ?
By PrinceSwaraj in forum AudioReplies: 16Last Post: 17th Apr 2018, 15:21 -
dts 1509 to dts 755
By nixiejames in forum AudioReplies: 9Last Post: 25th Mar 2016, 11:00
