one of the anime that I love is NANA (2006), I have R2J DVD (NTSC,30000/10001,868x480), those DVD suffer a lot of banding, dot noise, I used vapoursynth to fix interlace,and balance between banding and dithering
any suggestion
Code:import vapoursynth as vs import sys import importlib import functools core = vs.get_core() sys.path.append(r"C:\vs\VapourSynth64Portable\Scripts") ASTDR = importlib.machinery.SourceFileLoader("ASTDR", r"C:\vs\VapourSynth64Portable\Scripts\ASTDR.py").load_module() havsfunc = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\havsfunc.py").load_module() G41Fun = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\G41Fun.py").load_module() NRDB = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\NRDB.py").load_module() import mvsfunc as mvf clip = core.ffms2.Source(r"F:\0\15short/13-002.mkv",fpsnum=30000, fpsden=1001) clip = havsfunc.QTGMC(clip, Preset='Very Slow', SourceMatch=3, TR2=1,Rep2=1, Lossless=2, TFF=True,FPSDivisor=2,NoiseProcess=1, NoiseRestore=0.0, Denoiser="dfttest", DenoiseMC=True, NoiseTR=2, Sigma=4.0 ) clip = core.placebo.Resample(clip,width=864,height=480, filter = "ewa_lanczos", sx = 0.0, sy = 0.0, antiring = 0.0, lut_entries = 64, cutoff = 0.001, sigmoidize = 1, linearize = 1, sigmoid_center = 0.75, sigmoid_slope = 6.5, trc = 1) clip = G41Fun.SuperToon(clip) clip = core.dfttest.DFTTest(clip , ftype=0, sigma=8.0, sigma2=8.0, pmin=0.0, pmax=500.0, sbsize=16, smode=1, sosize=12, tbsize=3, tmode=0, tosize=0, swin=0, twin=7, sbeta=2.5, tbeta=2.5, zmean=True, f0beta=1.0, nlocation=None, slocation=None, ssx=None, ssy=None, sst=None, ssystem=0, planes=[0, 1, 2], opt=0) clip = NRDB.NRDB(clip, deband="", db_Y=64, db_Cb=0, db_Cr=0, grainY=0, grainC=0, dynamic_grain=False, keep_tv_range=False, nr="", planes=[0], sigma=4.0, sigma2=4.0) super = core.mv.Super(clip,pel=2, rfilter =4 ) bv1 = core.mv.Analyse(super, isb = True, delta = 1, overlap=4) fv1 = core.mv.Analyse(super, isb = False, delta = 1, overlap=4) bv2 = core.mv.Analyse(super, isb = True, delta = 2, overlap=4) fv2 = core.mv.Analyse(super, isb = False, delta = 2, overlap=4) bv3 = core.mv.Analyse(super, isb = True, delta = 3, overlap=4) fv3 = core.mv.Analyse(super, isb = False, delta = 3, overlap=4) clip = core.mv.Degrain3(clip,super,bv1,fv1,bv2,fv2,bv3,fv3,thsad=400) clip = havsfunc.HQDeringmod(clip, nrmode=2, darkthr=3.0) clip = havsfunc.FastLineDarkenMOD(clip, strength=48, protection=5, luma_cap=191, threshold=4, thinning=0) clip.set_output()
Results 1 to 10 of 10
Tdecimate provides the underlying 24 fps, rather than the 30 with duplicate frames.
Use it instead of the qtgmc. -
If you just want to reduce the posterization you can use GradFun3() or GradFun2DBMod(). Then you have to encode with enough bitrate to retain the added noise. Otherwise you might as well not bother.
much better any other suggestions ?
Code:import vapoursynth as vs import sys import importlib import functools core = vs.get_core() sys.path.append(r"C:\vs\VapourSynth64Portable\Scripts") havsfunc = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\havsfunc.py").load_module() mvs = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\mvsfunc.py").load_module() G41Fun = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\G41Fun.py").load_module() NRDB = importlib.machinery.SourceFileLoader("havsfunc", r"C:\vs\VapourSynth64Portable\Scripts\NRDB.py").load_module() clip = core.ffms2.Source(r"F:\testarea/04-006.mkv",fpsnum=30000, fpsden=1001) clip = core.tcomb.TComb(clip, mode=2) clip = mvs.AssumeTFF(clip ) matched_clip = core.vivtc.VFM(clip,1,cthresh=10) clip= core.vivtc.VDecimate(matched_clip) clip = core.placebo.Resample(clip,width=864,height=480, filter = "ewa_lanczos", sx = 0.0, sy = 0.0, antiring = 0.0, lut_entries = 64, cutoff = 0.001, sigmoidize = 1, linearize = 1, sigmoid_center = 0.75, sigmoid_slope = 6.5, trc = 1) clip = havsfunc.MCTemporalDenoise(clip) clip = core.f3kdb.Deband(clip) super = core.mv.Super(clip,pel=2, rfilter =4 ) bv1 = core.mv.Analyse(super, isb = True, delta = 1, overlap=4) fv1 = core.mv.Analyse(super, isb = False, delta = 1, overlap=4) bv2 = core.mv.Analyse(super, isb = True, delta = 2, overlap=4) fv2 = core.mv.Analyse(super, isb = False, delta = 2, overlap=4) bv3 = core.mv.Analyse(super, isb = True, delta = 3, overlap=4) fv3 = core.mv.Analyse(super, isb = False, delta = 3, overlap=4) clip = core.mv.Degrain3(clip,super,bv1,fv1,bv2,fv2,bv3,fv3,thsad=400) clip = havsfunc.HQDeringmod(clip, nrmode=2, darkthr=3.0) clip = havsfunc.FastLineDarkenMOD(clip, strength=48, protection=5, luma_cap=191, threshold=4, thinning=0) clip = G41Fun.SuperToon(clip) clip.set_output()
Field blends srestore isn't dealing with nicely
By bruno321 in forum Video ConversionReplies: 12Last Post: 23rd Oct 2020, 07:02 -
Dealing with a very large MTS file
By RandyS555 in forum EditingReplies: 8Last Post: 18th Jan 2019, 09:02 -
Dealing with OPUS audio of MP4/WEBM/MKV
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2017, 01:36 -
Dealing with strong deblocking
By Marcoh_ in forum RestorationReplies: 17Last Post: 22nd Apr 2017, 21:48 -
Dealing with heavy blending [VHS, AviSynth]
By magiblot in forum RestorationReplies: 1Last Post: 7th Sep 2016, 13:56
