Results 1 to 9 of 9
    Aug 2010
    israel
    Greetings
    Trying desperately to download from:
    https://www.numeridanse.tv/en/dance-videotheque/petite-mort?s
    17 min. modern dance
    I tried:
    youtube-dl
    youtube-dlg 0.4
    youtube-dl gui 2.251
    all failed.
    there is a warning: could not send HEAD request to the above link
    and an error: SSL_CERTIFICATE_VERIFY_FAILED
    And something very similar in cmd screen when using youtube-dl
    youtube-dlg gives an immediate error after pre-processing
    what am I doing wrong
    error window for youtube-dl gui is attached
    but tvdownloader does the job!
    I'd still like to learn to work with youtube-dl
    are there any special settings/options?
    thank you
  2. IDM can do the job.
    youtube-dl can also do it
    youtube-dl https://www.numeridanse.tv/en/dance-videotheque/petite-mort
    Aug 2010
    israel
    I tried and got the same error:
    e:\Multimedia\Youtube-dl gui>youtube-dl https://www.numeridanse.tv/en/dance-videotheque/petite-mort
    [generic] petite-mort: Requesting header
    WARNING: Could not send HEAD request to https://www.numeridanse.tv/en/dance-videotheque/petite-mort: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)>
    [generic] petite-mort: Downloading webpage
    ERROR: Unable to download webpage: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)> (caused by URLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)'),))
    Aug 2010
    israel
    furthermore I tried streamlink and got this funny error:
    e:\Multimedia\streamlink\bin>streamlink https://www.numeridanse.tv/en/dance-videotheque/petite-mort
    error: No plugin can handle URL: https://www.numeridanse.tv/en/dance-videotheque/petite-mort
  5. youtube-dlc works. Make sure you use recent/updated version
  6. Originally Posted by flannob View Post
    streamlink does not work the same way as youtube-dl so inputing a website URL won't do any good
    I see you're running youtube-dl from the GUI directory, which I hear hasn't been updated in quite some time. well, maybe you should try a fresh download
  7. youtube-dl --no-check-certificate
    Aug 2010
    israel
    LZAA: mant many thanks!!
    Aug 2010
    israel
    poisondeathray: many many thanks
    I didn't know youtube-dlc existed and thanks for that too
