Try NordVPN to access Netflix or other streaming services from any country and also surf safely!
    Nov 2020
    Dublin, Ireland
    I've converted a video to a DVD-compliant MPEG2 with MainConcept MPEG encoder, but when I author a DVD from it with DVD-lab Pro, the picture freezes after about 2 minutes.
    I've been able to author another DVD from the same file using DVDstyler (without any re-encoding) with no issue, but I want to have the ability to use some of the features of DVD-lab Pro that DVDstyler doesn't have.
    Any help would bemuch appreciated.
    Which version of MainConcept, exactly?
    Freezing can be many things. Everything from a bad spots on the HDD, to a bad GOP selection.
    Nov 2020
    Dublin, Ireland
    I'm not really sure what version it is. Whatever version that was included in EditStudio 6, before they stopped including it in 2012 because the license expired between Mediachance and Rovi.
  4. DECEASED
    Jun 2009
    Heaven
    You can try a different (older) version of DVD-lab PRO, OR use a different MPEG-2 encoder (HCenc, TMPGenc, whatever)
    I have already seen some streams created by MainConcept Reference which are not recognized by LAV Filters or/and VirtualDub
    and they are always rejected by the old TMPGenc's multiplexer
    "Like this facility, I don't exist."
    How do you not know what version was used?
    Um ... odd.
