I am trying to understand the conversion options.
If I convert Apple Lossless to Flac using MediaHuman and settings [stereo, 48000Hz] the files are large.
If I convert Apple Lossless to Flac using FFmpeg and settings [Sample rate == source, Channels == source, -compression_level 0] the files are .15MB smaller.
Is this possible:
The forced sample rate set to 48000Hz was larger than the native Sample rate.
What is MediaHuman? If you are on a Windows machine, just download and install something like foobar2000. I use foobar2000 as a music player and it has options built in to edit metadata and do conversions. If the source sampling rate is 44.1khz, then there is no reason to use 48khz. I am not totally sure what converter foobar2000 actually uses, but ffmpeg's conversion is very high quality.
Not sure if this answers the original question, but in general: lossless files may be compressed but they still have to track their source quality settings.
So a mono signal would have less bitrate than a stereo signal (though this might not be fully 2x, depending on interchannel correllation). Similarly, the higher the sample rate, the more data is going to be needed to represent it.
best software for flac and mp3 conversion?
By mol3000 in forum AudioReplies: 2Last Post: 29th Jan 2019, 20:16 -
Premiere Flac 5.1 or lossless audio export
By Noctis001 in forum AudioReplies: 0Last Post: 9th Jun 2018, 12:21 -
Understanding conversion to lossless
By moxiecat in forum Video ConversionReplies: 22Last Post: 19th Jan 2018, 21:35 -
Question about FLAC & lossless
By smackyourfupa in forum AudioReplies: 4Last Post: 28th May 2017, 09:50 -
MPEG-2 TS (.ts) Lossless Conversion
By Beestin in forum Video ConversionReplies: 15Last Post: 20th Nov 2016, 16:47
