Trying to use VIVTC on RGB/YUV444P8 content, reading http://www.vapoursynth.com/doc/plugins/vivtc.html
I came up with:
This does not crash, but it also doesn't remove the combing,...Code:# adjusting color space from RGB24 to YUV444P8 since VsVIVTC doesn't support RGB24 clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P8, matrix_s="470bg", range_s="full") # converting YUV444P8 clip to YUV420P8 for VFM yv12=core.resize.Bicubic(clip=clip,format=vs.YUV420P8, range_s="full") # Forcing chroma to False for VFM due to usage of yv12 clip = core.vivtc.VFM(clip=yv12, clip2=clip, order=0, chroma=False) # converting YUV444P8 clip to YUV420P8 for VDecimate yv12=core.resize.Bicubic(clip=clip,format=vs.YUV420P8, range_s="full") # Forcing chroma to False for VDecimate due to usage of yv12 clip = core.vivtc.VDecimate(clip=yv12, clip2=clip, chroma=False)# new fps: 23.976
-> Can someone tell my how this should look like to actually work? It's probably something stupid I'm overlooking or misunderstood.
Cu Selur
If you read your link
, VFM does not have post processing built in like TFM (pp=blah); you need to apply it afterwards . There is an example in the docs with FrameEval and functools
YUV444P8 is supported, there should be no reason to convert to YUV420P8 at that stage -
Ahhh,.. that helped:
does the job.Code:clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P8, matrix_s="470bg", range_s="full") yv12=core.resize.Bicubic(clip=clip,format=vs.YUV420P8, range_s="full") # Forcing chroma to False for VFM clip = core.vivtc.VFM(clip=yv12, clip2=clip, order=0, mode=4, chroma=False) deinterlaced_clip = core.eedi3.eedi3(clip, field=1) # or other deinterlacer def postprocess(n, f, clip, deinterlaced): if f.props['_Combed'] > 0: return deinterlaced else: return clip postprocessed_clip = core.std.FrameEval(clip, functools.partial(postprocess, clip=clip, deinterlaced=deinterlaced_clip), prop_src=clip) clip = core.vivtc.VDecimate(clip=postprocessed_clip, chroma=True) # new fps: 23.976
RGB Output Through SCART
By nman971 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jul 2019, 04:34 -
RGB Range help
By attackworld in forum ComputerReplies: 5Last Post: 25th Apr 2019, 03:42 -
RGB to YUV to RGB
By chris319 in forum ProgrammingReplies: 70Last Post: 20th Feb 2017, 17:49 -
Handbrake issue with RGB
By yosuke30 in forum Video ConversionReplies: 7Last Post: 1st May 2016, 07:04 -
Camera ffdshow/mjpeg capture colors are all wrong (possible yuv/rgb issue)
By alienvenom in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2016, 09:06
