I capture my video with avi_io abd huffyuv, then edit in virtualdub. In order to frameserve my edited video to tmpgenc I have to save the avi as a segmented file then open it again. Is this normal, or just a problem with my (probably quite old) version of virtualdub?
I switch it to direct stream copy, since all I do is remove the adverts, but when I framserve without re-saving, the adverts remain there.
Any advice appreciated
Nick
You shouldn't have to save your file down at all after deleting frames in Vdub. Make your edits, then go to FILE, START FRAMESERVER, save the virtual avi (movie.vdr.avi) then open this up as the source in your encoder.
See under Conversion for Vdub frameserving guide.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 22:39 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 05:59 -
can I download the version prior to 2.5 somewhere?
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 21st May 2008, 17:31 -
Edit FLV with VirtualDub?
By JeffM in forum EditingReplies: 14Last Post: 12th Apr 2008, 14:17
