Hi All,
New here and new to video editing. I have an ASF file exported from a security camera DVR. I want to create a hyper-lapse of the 8-ish hour 10GB video, but I'm running into problems. Seems that this isn't a typical ASF file and it has a broken index.
Output from MediaInfoXP is as follows
When I play it in VLC, it tells me that it's only 1:42:something long, not the 8-ish hours long. However, I can play it beyond that timestamp. The content is there. I can seek everywhere but maybe the last 10% of the displayed length. Windows Media shows the right length, but I can only seek in the very beginning of the file.General
Complete name : C:\Users\Public\FLIRCloudClient\FLIRCloudClient\Re cord\DownLoad\192.168.21.91_BACKYARD_main_20201109 072932_152236.asf
Format : Windows Media
File size : 10.2 GiB
Duration : 7 h 48 min
Overall bit rate : 3 128 kb/s
Maximum Overall bit rate : 1 512 kb/s
Encoded date : UTC 2020-11-12 11:29:44.443
Video
Format : AVC
Codec ID : H264
Bit rate : 2 997 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 15.152 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.095
Stream size : 9.80 GiB (96%)
I cannot use AsfBin because of the funny format. It doesn't recognize the file. Any attempt that I've tried with ffmpeg (with various switches) only writes out the first approx. 2GB of the file and bails out, but not with an error. It just thinks it's done.
How do I proceed here? Any help would be appreciated.
Thanks,
Jason
Results 1 to 9 of 9
This thread → { https://forum.videohelp.com/threads/399447-Newbie-help-How-to-edit-RM-file-audio } is about a broken RealMedia file, but the solution given (reencode through Avisynth) may apply to your problem as well.
As you can see, H.264 video in the ASF container is pure evil, much worse than H.264 in AVI...
<RANT>If the goal is digital video recording, they should choose transport stream or program stream, not some proprietary Microsoft garbage.</RANT>
Using SolveigMM ASF Multiplexer in GraphStudio MIGHT work too, assuming the problematic file is not excessively-problematic of course"Programmers are human-shaped machines that transform alcohol into bugs." -
So far, so good. It just made it past the false end of the file. It's pretty slow, though. Converting/saving at maybe 3.1x speed.
Thank you.
Thank you as well. I'm going to stick w/ VLC because I have it and don't need to learn anything else. I appreciate the response just the same. -
The slow effort w/ VLC did work!
Thanks, but I tried that and it didn't work.
Like I said, it would simply stop at that 1:42: something spot and give me a 2GB file. Are there any other switches that can be added to tell it to ignore the index and simply process the content in the file? Adding "-r 15" didn't work nor did "-map 0". Using ffmpeg would be my preferred approach since I can create my hyperlapse in one step instead of multiple. I have a few files to do this to (and I expect more in the future). -
Maybe -fflags +genpts before the input file. That tells ffmpeg to generate new timecodes.
AVI file - missing or broken index
By rhiannonj in forum Newbie / General discussionsReplies: 30Last Post: 5th May 2024, 14:19 -
Powerdirector better than Vegas rendering H264 AVC
By zizouillette in forum EditingReplies: 10Last Post: 1st Nov 2020, 18:20 -
H265/HEVC to H264/AVC
By Daringbaaz in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2019, 11:34 -
PAFF H264/AVC encoding
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2016, 15:42 -
CRF of VP8 vs. AVC/h264
By smitbret in forum Video ConversionReplies: 1Last Post: 18th Jan 2016, 17:03
