Hello
I've been searching for a solution for this for quite some time..
I have a transcript that looks like this:
I need to turn it into a subtitle file, Any trick I can use so I don't have to write the time-codes manually ?Code:0:00:00,048(upbeat music) 0:00:07,010To start everything off. 0:00:08,570We're gonna start thinking about 0:00:09,980where you can actually go in the industry. 0:00:11,520And one of the best ways I found to see what's out there is 0:00:15,210to follow the title of this actual episode, Trading Places. 0:00:18,928One thing I think that's a great thought experiment ...
Thank you
Save you transcript in a text file... start Subtitle Edit, and use File - Open... choose your saved text file, and then SE should open it
Adjusting SUP subtitle positions in Subtitle Edit
By CWCprime in forum SubtitleReplies: 3Last Post: 31st Jul 2020, 02:51 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 14:15
